1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Kuldeep Joshi <[email protected]>
Date: Fri, 6 Aug 2021 14:11:07 +0000
> I am attaching the screenshot of the userCalc.bob file in phoebus, display builder with the Format set as string, Still the problem persists. The moment I change it to just .CALC I am able to enter 36 chars.
Can't duplicate. This is my example record:
# Executed with softIoc -d ... from EPICS R7.0.4.1
record(calc, "test_calc")
    field(SCAN, "1 second")
    field(CALC, "RNDM*100")
The CALC is served as a STRING and works OK with the default format.
The CALC$ is served as a BYTE array, by default displayed as such, so need to set Format do String:
So you have a different release of EPICS base?
Did you switch phoebus to default to pva:// instead of ca://?
-Kay
Re: Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Prev: RE: cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Next: RE: Getting started with EPICS lecture videos Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Next: Re: Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
