1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: "rpcgen: Command not found" When asyn
From: Matt Clarke via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Thu, 14 Oct 2021 06:18:18 +0000
Actually the command might be:
yum --enablerepo=PowerTools install rpcgen
Matt
From: Tech-talk <[email protected]> on behalf of Matt Clarke via Tech-talk <[email protected]>
Reply-To: Matt Clarke <[email protected]>
Date: Thursday, 14 October 2021 at 08:17
Hi.
I think on Centos 8 you need to install rpcgen separately as it is not included in glib.
I.e. yum install rpcgen
You might also need to install libtirpc-devel.
Cheers,
Matt
From: Tech-talk <[email protected]> on behalf of 网易邮件中心 via Tech-talk <[email protected]>
Reply-To:
网易邮件中心 <[email protected]>
Date: Thursday, 14 October 2021 at 06:56
Subject: "rpcgen: Command not found" When asyn
Hi all,
    I use centos 8(64), base7.0.6.1,asyn from the github( https://github.com/epics-modules  )
    When I make tha asyn module, I met the question.
make[2]: Entering directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
cp ../vxi11/vxi11intr.rpcl .
rpcgen  vxi11intr.rpcl
make[2]: rpcgen: Command not found
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'.  Stop.
make[2]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn'
make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: asyn.install] Error 2
I have tried "yum install glibc-utils and yum install glibc."       Neither worked.
How I could fix it?
Thanks
Liang
"rpcgen: Command not found" When asyn 网易邮件中心 via Tech-talk
Re: "rpcgen: Command not found" When asyn Matt Clarke via Tech-talk
Prev: Re: "rpcgen: Command not found" When asyn Matt Clarke via Tech-talk
Next: Re: Periodically calling shell functions in an IOC Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Fwd: "rpcgen: Command not found" When asyn Han Lee via Tech-talk
