1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Fwd: "rpcgen: Command not found" When asyn
To: EPICS tech-talk <[email protected]>
Date: Thu, 14 Oct 2021 13:29:28 -0700
Forgot to cc to tech-talk.
Han
---------- Forwarded message ---------
Date: Wed, Oct 13, 2021 at 9:33 PM
Subject: Re: "rpcgen: Command not found" When asyn
To: 网易邮件中心 <[email protected]>
Hi Liang,
You need to install rpcgen package. Please see the following hints (enable powertools, and install epel-release)
dnf update;
dnf config-manager --set-enabled powertools
 dnf update; dnf -y install "epel-release"; dnf update; dnf install rpcgen
Note that epel-release isn't related with rpcgen, but you need this for more EPICS module installations.
HTH,
Han
On Wed, Oct 13, 2021 at 9:26 PM 网易邮件中心 via Tech-talk <[email protected]> wrote:
Hi all,
    I use centos 8(64), base7.0.6.1,asyn from the github( https://github.com/epics-modules  )
    When I make tha asyn module, I met the question.
make[2]: Entering directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
cp ../vxi11/vxi11intr.rpcl .
rpcgen  vxi11intr.rpcl
make[2]: rpcgen: Command not found
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'.  Stop.
make[2]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn'
make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: asyn.install] Error 2
I have tried "yum install glibc-utils and yum install glibc."       Neither worked.
How I could fix it?
Thanks
Liang
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
"rpcgen: Command not found" When asyn 网易邮件中心 via Tech-talk
Prev: Re: Periodically calling shell functions in an IOC Ralph Lange via Tech-talk
Next: ADAravis multiple image mode fail for Basler raL12288-8gm Katie Matusik via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: "rpcgen: Command not found" When asyn Matt Clarke via Tech-talk
