1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Metadata for an NTTable
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
Date: Fri, 15 Oct 2021 15:53:24 +0000
Hi all,
We're in the process of writing a pythonSoftIOC that will allow every parameter from a PandABox to be set. It will create the records by introspecting the PandA at startup, then run an IOC which will expose them over CA and PVA (via QSRV). All of the parameter types map to NormativeTypes, but there is more metadata for tables than will fit in the NTTable spec. Specifically:
  • All PandA table columns are integer type, but some should be interpreted as enums
  • The tables are writeable, and have descriptions, units, low and high limits for each column
The first could be solved by adding an optional choices​ structure like enum_t with entries for the columns which are enums and the second could be solved by adding optional display​ and control​ structures like NTScalar with entries for each column with this metadata.
I could just add these to the IOC, but it would be good to discuss whether it is a good idea with others and make an addition to the normative types document.
Who would the right people be to discuss this with?
Tom
Re: Metadata for an NTTable White, Greg via Tech-talk
Prev: Re: Channel Archiver data into Archiver Appliance? Hu, Yong via Tech-talk
Next: Re: Does EPICS support MVME3100 under Linux? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Does EPICS support MVME3100 under Linux? Johnson, Andrew N. via Tech-talk
Next: Re: Metadata for an NTTable White, Greg via Tech-talk
