1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Does EPICS support MVME3100 under Linux?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Dmitry Yu. Bolkhovityanov" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 15 Oct 2021 16:40:22 +0000
Hi Dmitry,
On Oct 15, 2021, at 2:40 AM, Dmitry Yu. Bolkhovityanov via Tech-talk <[email protected]> wrote:
The subject says it all: does EPICS VME subsystem support MVME3100 under Linux, or is RTEMS mandatory?
The EPICS devLib API can be used on Linux if you have a suitable implementation of the target-specific support for it (a struct devLibVME object with pointers to the necessary routines). However there certainly isn’t one included with EPICS for Linux on the MVME3100 board, and I’m not sure if anyone else in the community has ever developed one. In general Linux won’t have good support for VME interrupts because the IOC runs as a regular process in user space and no matter how the associated kernel driver signals the arrival of an interrupt to user-space it will not be fast.
RTEMS isn’t mandatory, but it might be the easiest way to control VME I/O devices from that board.
Alternatively, does anybody have any experience with alternative VME SBCs, such as Duagon (ex-MEN) A25, Kontron ALMA2f-based boards, or Concurrent Technologies Tundra-based x86 boards?
Not personally. Be aware that most existing EPICS drivers for VME I/O cards have been written for big-endian CPUs (m68k and/or PowerPC) and might need changes to work on little-endian CPUs (Intel/AMD) to swap the byte order when accessing registers on other VME cards. Some VME interfaces perform byte-swapping automatically though, so it may depend on the specific CPU board whether you need to do that or not.
- Andrew
Complexity comes for free, simplicity you have to work for.
Does EPICS support MVME3100 under Linux? Dmitry Yu. Bolkhovityanov via Tech-talk
Prev: Metadata for an NTTable Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: aravisGigE driver for AVT Manta camera Hasan SANSAR via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Does EPICS support MVME3100 under Linux? Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Metadata for an NTTable Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
