1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: IOC in Docker not responding to caget from another host
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Paduan Donadio, Marcio" <marcio at slac.stanford.edu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 5 Nov 2021 11:38:16 -0700
On 11/5/21 10:53 AM, Paduan Donadio, Marcio wrote:
> Michael, this idea of using telnet was very useful. I ended up discovering that the firewall was blocking port 5064 in Ubuntu1. I've opened the port, could connect through telnet, but caget still refuses to communicate. I've tried both the broadcast address and Ubuntu1 specific IP in EPICS_CA_ADDR_LIST.
Failure to connect w/ 'telnet' is good indication of a firewall problem.  However, success only tells you that TCP traffic can get through.  You also need to open up 5064 (and should open 5065) for UDP traffic.
Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
Re: IOC in Docker not responding to caget from another host Florian Feldbauer via Tech-talk
Re: IOC in Docker not responding to caget from another host Lucas Russo via Tech-talk
Re: IOC in Docker not responding to caget from another host Michael Davidsaver via Tech-talk
Prev: Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
Next: Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
ANJ, 05 Nov 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
