1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Wed, 8 Dec 2021 16:54:22 +0000
Hello EPICS-community,
as the title of this thread says, I’m wondering if it is possible to dynamically select where an incoming frame is placed within the HDF5-Files structure. For example, while capturing frames in Stream-mode with the default HDF5-Files structure layout, all incoming frames are placed to:
entry -> instrument -> detector -> data
Now I want to load an individual hdf5-layout.xml with the additional location “flat”:
entry -> instrument -> detector -> flat
Is there a way that I can switch (via an EPICS-PV) the location where the next frame is stored, either “entry -> instrument -> detector -> data” or “entry -> instrument -> detector -> flat”, while the h5-files is still opened? Example scan with a total of 1000 frames, all should go into one h5-file:
  • h5-files is opened
  • the first 20 frames are placed to entry -> instrument -> detector -> flat
  • the next 960 frames are placed to entry -> instrument -> detector -> data
  • the last 20 frames are placed to entry -> instrument -> detector -> flat
  • h5-files is closed
In the AreaDetector user-guide there is the following section:
https://areadetector.github.io/master/ADCore/NDFileHDF5.html#selective-positional-placement-of-individual-frames
I switched on the Position mode and put Index N to 0 (or 1) and put Name N to “flat” but I get a Write error status. I think I don’t understand the handling of the dataset dimensions within the h5-file and don’t know if my frame-placement sequence is actually realizable. Can someone help?
Thanks!
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
[email protected]
Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Pete Jemian via Tech-talk
Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Mark Rivers via Tech-talk
Prev: Re: Need clarification on UDP Broadcasting to multiple IOCs on same PC Ralph Lange via Tech-talk
Next: Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
