1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers?
From: Mrinal Bera via Tech-talk <[email protected]>
To: Kevin Peterson <[email protected]>
Date: Tue, 14 Dec 2021 04:06:10 +0000
Thanks, Kevin for the info! We have now decided to go ahead with OMS MAXv cards.
Mrinal
> On Dec 13, 2021, at 4:26 PM, Kevin Peterson <[email protected]> wrote:
> The MAXv has internal filters on the limit lines that the MAXnet controller lacks:
>  https://epics.anl.gov/tech-talk/2017/msg00243.php
> If there is noise on the limit lines of a MAXnet axis, moves will stop prematurely.  A significant amount of noise can make motors unusable from EPICS.
> Kevin
> On 12/8/21 08:18, Mark Rivers via Tech-talk wrote:
>> Hi Mrinal,
>> There is now a 10-axis version of the MAXnet, so you could use just 2 of them.  The MAXnet driver inherits from asynMotorController, so it should definitely support multiple controllers in the same IOC.  Each is a separate asynPortDriver object with a different asyn port name.
>> If you are planning to use this on a beamline that already has many VME cards like the OMS MAXv then I wonder if it is the best solution.  You will need to build a box with power supply and connectors for the MAXnet, while adding from more MAXv cards is simpler. If you want an Ethernet solution there are more powerful controllers available that already have nice packaging.
>> Mark
Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mark Rivers via Tech-talk
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Kevin Peterson via Tech-talk
Prev: Re: ADVimba memory leak ? John Dobbins via Tech-talk
Next: Re: Log4Shell approaches Matt Clarke via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Kevin Peterson via Tech-talk
Next: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Sintschuk, Michael via Tech-talk
