1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Can single soft-IOC control multiple OMS SPI-MAXnet controllers?
To: Mrinal Bera <[email protected]>
Date: Wed, 8 Dec 2021 19:36:27 +0000
Hi Mrinal,
An off-the-shelf Ethernet motor controller with fast delivery time is the Newport XPS-D.  Unlike the MAXnet/Step Pak it can drive both stepper and DC motors, and has advanced coordinated motion features.
We are using 16 Newport XPS controllers of various generations at the beamlines at APS sector 13.  Since you are at APS sector 15 we are close by to help!
Sent: Wednesday, December 8, 2021 1:27 PM
Cc: [email protected]
Subject: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers?
Hi Mark,
Thanks for your response. The reason I chose SPI-MAXnet 8000 8-axis over MAXnet 10-axis version is: as per the OMS website SPI-MAXnet 8000 can directly go into Step-Pak Plus rack along with the 8 driver modules. Hence the whole system will be contained within a Step-Pak rack without building connectors for the MAXnet. I am also considering the ACS Controls MP4U unit. Can you suggest any other Ethernet-ready motor controllers?  I started looking at these options other than the VME crate for having compact standalone systems with multiple axis support, and most importantly, with the least lead time.
Best,
Mrinal
Mrinal Kanti Bera, PhD
NSF’s ChemMatCARS
University of Chicago
9700 S Cass Ave Bldg 434D
Argonne, IL-60439
United States
Phone: +1-630-252-0472
On Dec 8, 2021, at 8:18 AM, Mark Rivers <[email protected]> wrote:
Hi Mrinal,
There is now a 10-axis version of the MAXnet, so you could use just 2 of them.  The MAXnet driver inherits from asynMotorController, so it should definitely support multiple controllers in the same IOC.  Each is a separate asynPortDriver object with a different asyn port name.
If you are planning to use this on a beamline that already has many VME cards like the OMS MAXv then I wonder if it is the best solution.  You will need to build a box with power supply and connectors for the MAXnet, while adding from more MAXv cards is simpler.  If you want an Ethernet solution there are more powerful controllers available that already have nice packaging.
From: Tech-talk <[email protected]> on behalf of Mrinal Bera via Tech-talk <[email protected]>
Sent: Wednesday, December 8, 2021 3:13 AM
To: [email protected] <[email protected]>
Subject: Can single soft-IOC control multiple OMS SPI-MAXnet controllers?
While looking for 18 axis application, I came across the OMS SPI-MAXnet 8000 8-axis controller. For the 18 axis application, I would need 3 of such controllers. As the EPICS motor record support OMS-MAXnet controllers, would it be possible to configure all the three controllers under a single soft-IOC, or do I need to run 3 separate soft-IOCs?
Best,
Mrinal
Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mark Rivers via Tech-talk
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Prev: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Next: Quickly Connecting EPICS iocsh variables to records Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Kevin Peterson via Tech-talk
