1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Quickly Connecting EPICS iocsh variables to records
To: Talk EPICS Tech <[email protected]>
Date: Wed, 8 Dec 2021 11:02:03 -1000
I have an EPICS3.14.12.8 system.
What's the easiest way to connect "variable(foo, int)" lines in my dbd file to epics records?
I have many such variables throughout my code for debugging using epicsExportAddress(int, foo) in my C code.
I think I need to make a new db or template specifying new records (eg., asub type) of all the corresponding variables. The SNAM field of these records specify C routines connecting the variable memory to the corresponding records.
Is that the best approach? Has anyone else done this sort of thing? Seeing my iocsh debug variable in a display would be super helpful.
-Matt
Re: Quickly Connecting EPICS iocsh variables to records Johnson, Andrew N. via Tech-talk
Prev: RE: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mark Rivers via Tech-talk
Next: Re: Quickly Connecting EPICS iocsh variables to records Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: AW: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Sintschuk, Michael via Tech-talk
