1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: AW: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 9 Dec 2021 14:09:49 +0000
Hi Pete, hi Mark,
yes, this is exactly what I was looking for!
Thank you both for the detailed examples!!
Michael
Von: Mark Rivers <[email protected]>
Gesendet: Mittwoch, 8. Dezember 2021 20:00
An: [email protected]; Sintschuk, Michael <[email protected]>
Betreff: Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file
Hi Michael,
What you would like to do with flat and data images is exactly what we are currently doing at the tomography beamlines at the APS. We are using the Python package called tomoscan:
The tomoScan.template file defines the locations of where the data should be stored in the HDF5 file:  https://github.com/tomography/tomoscan/blob/master/tomoScanApp/Db/tomoScan.template
# Location for data in HDF5 file
record(stringout, "$(P)$(R)HDF5ProjectionLocation")
   field(VAL, "/exchange/data")
record(stringout, "$(P)$(R)HDF5DarkLocation")
   field(VAL, "/exchange/data_dark")
record(stringout, "$(P)$(R)HDF5FlatLocation")
   field(VAL, "/exchange/data_white")
record(stringout, "$(P)$(R)HDF5Location")
Here is an example of an HDF Layout file for the detector we use on one beamline: https://github.com/CARS-UChicago/GSECARS-EPICS/blob/master/iocBoot/ioc13bmd_pg1/tomoLayout.xml
It contains the following. The first line means that the NDArray attribute HDF5FrameLocation defines the location of the data in the HDF5 via the global  detector_data_destination which is understood by NDFileHDF5.
  <global name="detector_data_destination" ndattribute="HDF5FrameLocation" />
    <group name="exchange">
      <dataset name="frame_type" source="ndattribute" ndattribute="FrameType" when="OnFileClose" />
      <dataset name="data" source="detector">
        <!-- SaveDest = 0 : /exchange/data -->
        <attribute name="description" source="constant" value="ImageData" type="string" />
        <attribute name="axes" source="constant" value="theta:y:x" type="string" />
        <attribute name="units" source="constant" value="counts" type="string" />
      </dataset>
      <dataset name="data_dark" source="detector">
        <!-- SaveDest = 1 : /exchange/data_dark -->
        <attribute name="description" source="constant" value="DarkData" type="string" />
      </dataset>
      <dataset name="data_white" source="detector">
        <!-- SaveDest = 2 : /exchange/data_white -->
        <attribute name="description" source="constant" value="WhiteData" type="string" />
      </dataset>
tomoDetectorAttributes.xml is the detector attribute XML file for this detector.
It contains this line:
<Attribute name="HDF5FrameLocation" type="EPICS_PV" source="$(TS)HDF5Location" dbrtype="DBR_STRING"  description="Where to store frame in HDF5 file"/>
The Python code sets the location of the data in the HDF file:
This sets the data to be stored in /exchange/data_white for the flat fields:
        self.epics_pvs['HDF5Location'].put(self.epics_pvs['HDF5FlatLocation'].value)
From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]>
Sent: Wednesday, December 8, 2021 10:54 AM
To: [email protected] <[email protected]>
Subject: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file
Hello EPICS-community,
as the title of this thread says, I’m wondering if it is possible to dynamically select where an incoming frame is placed within the HDF5-Files structure. For example, while capturing frames in Stream-mode with the default HDF5-Files structure layout, all incoming frames are placed to:
entry -> instrument -> detector -> data
Now I want to load an individual hdf5-layout.xml with the additional location “flat”:
entry -> instrument -> detector -> flat
Is there a way that I can switch (via an EPICS-PV) the location where the next frame is stored, either “entry -> instrument -> detector -> data” or “entry -> instrument -> detector -> flat”, while the h5-files is still opened? Example scan with a total of 1000 frames, all should go into one h5-file:
  • h5-files is opened
  • the first 20 frames are placed to entry -> instrument -> detector -> flat
  • the next 960 frames are placed to entry -> instrument -> detector -> data
  • the last 20 frames are placed to entry -> instrument -> detector -> flat
  • h5-files is closed
In the AreaDetector user-guide there is the following section:
https://areadetector.github.io/master/ADCore/NDFileHDF5.html#selective-positional-placement-of-individual-frames
I switched on the Position mode and put Index N to 0 (or 1) and put Name N to “flat” but I get a Write error status. I think I don’t understand the handling of the dataset dimensions within the h5-file and don’t know if my frame-placement sequence is actually realizable. Can someone help?
Thanks!
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
[email protected]
AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Sintschuk, Michael via Tech-talk
Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Mark Rivers via Tech-talk
Prev: Re: Quickly Connecting EPICS iocsh variables to records Matt Rippa via Tech-talk
Next: Re: How to put the contents of a file in a waveform record Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Mark Rivers via Tech-talk
Next: Quickly Connecting EPICS iocsh variables to records Matt Rippa via Tech-talk
