1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Quickly Connecting EPICS iocsh variables to records
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 8 Dec 2021 13:19:53 -1000
Hi Andrew,
Thanks for your reply and the idea. Coincidentally, we already a version of the devSymb module that Micheal Davidsaver worked on to use registered variables. Now I know what to do.
-Matt
On Wed, Dec 8, 2021 at 11:47 AM Johnson, Andrew N. <[email protected]> wrote:
Hi Matt,
On Dec 8, 2021, at 3:02 PM, Matt Rippa via Tech-talk <[email protected]> wrote:
What's the easiest way to connect "variable(foo, int)" lines in my dbd file to epics records?
I have many such variables throughout my code for debugging using epicsExportAddress(int, foo) in my C code.
The code from the devSymb device support could probably be modified to make those variables available, but you’d have to replace the symbol lookup code with calls to epicsFindSymbol() (declared in epicsFindSymbol.h). I think I was originally planning to change that module to use the registered variables (possibly in addition to using epicsFindSymbol) but I never got around to actually doing that.
- Andrew
Complexity comes for free, simplicity you have to work for.
Quickly Connecting EPICS iocsh variables to records Matt Rippa via Tech-talk
Re: Quickly Connecting EPICS iocsh variables to records Johnson, Andrew N. via Tech-talk
Prev: Re: Quickly Connecting EPICS iocsh variables to records Johnson, Andrew N. via Tech-talk
Next: AW: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: PCAS 4.13.3 released Ralph Lange via Tech-talk
