1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: arv-tools not detecting USB3 camera
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: "Li, Ji" <[email protected]>, Mark Rivers <[email protected]>, "Engbretson, Mark S." <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Tue, 14 Dec 2021 18:00:56 +0000
Thanks Mark, and Ji,
Reboot of the server resolved the USB permissions.
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8
Point Grey Research-1E100123EF71-0123EF71 (USB3)
Point Grey Research-Blackfly BFLY-PGE-50S5C-18457368 (192.168.11.11)
Point Grey Research-Blackfly BFLY-PGE-50S5C-18481534 (192.168.11.12)
The aravis udev rules took action:
kgofron@xf11id-m3:/epics/iocs$ ls -l /dev/bus/usb/002/004
crw-rw-rw-+ 1 root root 189, 131 Dec 14 12:48 /dev/bus/usb/002/004
kgofron@xf11id-m3:/epics/iocs$ lsusb
Bus 002 Device 004: ID 1e10:3300 Point Grey Research, Inc.
The redhad documentation might be misleading, where it claims
'udevadm control --reload'  {where Ji tested '--reload-rules' option}
Definitely not rebooting is preferred. I have not tried unplug/replug the USB camera, that Mark suggested.
Thanks all for help,
Kaz
Sent: Tuesday, December 14, 2021 12:42 PM
To: Gofron, Kazimierz <[email protected]>; Mark Rivers <[email protected]>; Engbretson, Mark S. <[email protected]>
Cc: [email protected] ([email protected]) <[email protected]>
Subject: RE: arv-tools not detecting USB3 camera
Hi Kaz,
We had this problem at XPD-D. The rules need to be loaded on the RHEL8 computers (and after power cycling the computers):
udevadm control --reload-rules
udevadm trigger --type=devices --action="">
This is not available with dzdo. Marcus (maybe not in the mailing list) configured it for this to be applied automatically after power cycling.
You may also need to increase USBFS memory limit to like 2000.
-Ji
From: Tech-talk <[email protected]> On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: 2021年12月14日 11:56
To: Mark Rivers <[email protected]>; Engbretson, Mark S. <[email protected]>
Hello Mark,
I rebuild the aravis on RHEL8.4, and now USB support is included.
Found out that redhat libusbx-dev is equivalent to libusb-1.0 from debian.
kgofron@xf11id-m3:/epics/src/modules/aravis/src$ yum list installed | grep libusb
libusb.x86_64                                      1:0.1.5-12.el8                                 @rhel-8-for-x86_64-baseos-rpms
libusb-devel.x86_64                                1:0.1.5-12.el8                                 @codeready-builder-for-rhel-8-x86_64-rpms
libusbmuxd.x86_64                                  1.0.10-9.el8                                   @rhel-8-for-x86_64-appstream-rpms
libusbx.x86_64                                     1.0.23-4.el8                                   @anaconda
libusbx-devel.x86_64                               1.0.23-4.el8                                   @rhel-8-for-x86_64-baseos-rpms
Relevant part of meson-log.txt
kgofron@xf11id-m3:/epics/src/modules/aravis/build$ grep libusb meson-logs/meson-log.txt
Determining dependency 'libusb-1.0' with pkg-config executable '/usr/bin/pkg-config'
Called `/usr/bin/pkg-config --modversion libusb-1.0` -> 0
Called `/usr/bin/pkg-config --cflags libusb-1.0` -> 0
Called `/usr/bin/pkg-config libusb-1.0 --libs` -> 0
Run-time dependency libusb-1.0 found: YES 1.0.23
kgofron@xf11id-m3:/epics/src/modules/aravis$ meson build
The Meson build system
Version: 0.55.3
Source dir: /epics/src/modules/aravis
Build dir: /epics/src/modules/aravis/build
Build type: native build
Project name: aravis
Project version: 0.8.20
C compiler for the host machine: cc (gcc 8.4.1 "cc (GCC) 8.4.1 20200928 (Red Hat 8.4.1-1)")
C linker for the host machine: cc ld.bfd 2.30-93
C++ compiler for the host machine: c++ (gcc 8.4.1 "c++ (GCC) 8.4.1 20200928 (Red Hat 8.4.1-1)")
C++ linker for the host machine: c++ ld.bfd 2.30-93
Host machine cpu family: x86_64
Host machine cpu: x86_64
Compiler for C supports arguments -Wduplicated-branches: YES
Compiler for C supports arguments -Wimplicit-fallthrough: YES
Compiler for C supports arguments -Wmisleading-indentation: YES
Compiler for C supports arguments -Wstrict-prototypes: YES
Compiler for C supports arguments -Wunused: YES
Compiler for C supports arguments -Wunused-variable: YES
Compiler for C supports arguments -Wdeclaration-after-statement: YES
Compiler for C supports arguments -Wformat=2: YES
Compiler for C supports arguments -Wimplicit-function-declaration: YES
Compiler for C supports arguments -Winit-self: YES
Compiler for C supports arguments -Wmissing-include-dirs: YES
Compiler for C supports arguments -Wmissing-prototypes: YES
Compiler for C supports arguments -Wpointer-arith: YES
Compiler for C supports arguments -Wformat-nonliteral: YES
Compiler for C supports arguments -Wenum-conversion: NO
Compiler for C supports arguments -Wmaybe-uninitialized: YES
Compiler for C supports arguments -fvisibility=hidden: YES
Found pkg-config: /usr/bin/pkg-config (1.4.2)
Run-time dependency glib-2.0 found: YES 2.56.4
Run-time dependency gobject-2.0 found: YES 2.56.4
Run-time dependency gio-2.0 found: YES 2.56.4
Run-time dependency libxml-2.0 found: YES 2.9.7
Run-time dependency zlib found: YES 1.2.11
Library m found: YES
Has header "linux/if_packet.h" : YES
Program glib-mkenums found: YES
Configuring arvapi.h using configuration
Configuring arvfeatures.h using configuration
Configuring arvversion.h using configuration
Program g-ir-scanner found: NO
Found CMake: /usr/bin/cmake (3.18.2)
Run-time dependency gobject-introspection-1.0 found: NO (tried pkgconfig and cmake)
Run-time dependency gtk+-3.0 found: YES 3.22.30
Run-time dependency gstreamer-base-1.0 found: YES 1.16.1
Run-time dependency gstreamer-app-1.0 found: NO (tried pkgconfig and cmake)
Run-time dependency gstreamer-video-1.0 found: NO (tried pkgconfig and cmake)
Dependency gstreamer-base-1.0 found: YES 1.16.1 (cached)
Program gtkdoc-scan found: NO
Program xsltproc found: YES
Build targets in project: 36
Found ninja-1.8.2 at /usr/bin/ninja
{Essentially sees USBVision device, but fails to open BFLY-PGE-50S5C}
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8 -d all
[18:33:23.193] 🆆 interface> Failed to open USB device
[18:33:23.193] 🅸 interface> Found 0 USB3Vision device (among 8 USB devices)
[18:33:23.195] 🅸 interface> [GvInterface::discovery] Device 'Point Grey Research-Blackfly BFLY-PGE-50S5C-18457368' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:19:a3:18'
[18:33:23.195] 🅸 interface> [GvInterface::discovery] Device 'Point Grey Research-Blackfly BFLY-PGE-50S5C-18481534' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:1a:01:7e'
The relevant /etc/udev/rules.d/51-aravis.rules file content:
SUBSYSTEM=="usb", ATTRS{idVendor}=="1e10", MODE:="0666", TAG+="uaccess", TAG+="udev-acl"
Restarted udev rules after adding 51-aravis.rules
$systemctl restart systemd-udevd
The USB device permissions
kgofron@xf11id-m3:/etc/udev/rules.d$ ls -l /dev/bus/usb/002/003
crw-rw-r--. 1 root root 189, 130 Dec 13 17:39 /dev/bus/usb/002/003
In summary aravis is seeing the USB3 camera, but my user account is not getting access to the device.
Kazimierz
Sent: Monday, December 13, 2021 5:09 PM
To: Gofron, Kazimierz <[email protected]>; Engbretson, Mark S. <[email protected]>
Hi Kaz,
I am running Centos8, which is basically the same as RHEL8.  I have the same libusb-devel and libusbx-devel packages installed that you do, and no package with a name lib libusb-1.0.
[epics@viper meson-logs]$ yum list installed | grep libusb
libusb.x86_64                                      1:0.1.5-12.el8                                    @BaseOS
libusb-devel.x86_64                                1:0.1.5-12.el8                                    @PowerTools
libusbmuxd.x86_64                                  1.0.10-9.el8                                      @AppStream
libusbx.x86_64                                     1.0.22-1.el8                                      @anaconda
libusbx-devel.x86_64                               1.0.22-1.el8                                      @BaseOS
But the meson build worked for me.  This is the relevant part of meson-build.txt:
1.0.22
-I/usr/include/libusb-1.0
-L/usr/lib64 -lusb-1.0
-lusb-1.0
Dependency libusb-1.0 found: YES 1.0.22
Did you try rebuilding aravis?
Sent: Monday, December 13, 2021 3:59 PM
To: Engbretson, Mark S. <[email protected]>
Hi Mark,
I am not sure if USB3 dependency is compiled in. Frankly, I am not sure how to check it. I looked at meson-log.txt, and it confirms it by looking for  'libusb-1.0' package, which exists on debian, but not on RedHat (to my knowledge). I might be wrong here.
In meson-log.txt
"Preliminary CMake check failed. Aborting.
Run-time dependency libusb-1.0 found: NO (tried pkgconfig and cmake)"
"Called `/usr/bin/cmake --trace-expand --trace-format=json-v1 --no-warn-unused-cli --trace-redirect=cmake_trace.txt .` in /epics/src/modules/aravis/build/meson-private/cmake_libusb-1.0 -> 0
  -- Module search paths:    ['/', '/opt', '/usr', '/usr/local']
  -- CMake root:             /usr/share/cmake
  -- CMake architectures:    []
  -- CMake lib search paths: ['lib', 'lib32', 'lib64', 'libx32', 'share']
That indicates that it is looking for libusb-1.0 package, which to my knowledge does not exist on RedHat.
So maybe USB3 support is not compiled in, because libusb-1.0 does not exist (to my knowledge) on redhat.
Kaz
Sent: Monday, December 13, 2021 1:59 PM
Is the version of aravis that you are using built with the USB3 support enabled?
Sent: Monday, December 13, 2021 12:56 PM
Hi Mark,
Good point, and I did not install aravis udev rules yet.
However, when arv-tools is run as root, it does not detect the USB3 camera either.
[root@xf11id-m3 ~]# arv-tool-0.8 -d all
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.11.1 (192.168.11.255)
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 10.69.24.152 (10.69.24.255)
[11:52:14.711]
🅸 interface> [GvDiscoverSocket::new] Add interface 10.66.83.36 (10.66.83.255)
[11:52:14.711]
🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.122.1 (192.168.122.255)
[11:52:14.712]
[11:52:14.712]
Something else is missing on RedHat...
Kaz
Sent: Monday, December 13, 2021 1:11 PM
Do you have the aravis udev rules installed so that non root accounts can actually see the usb3 hardware?
Sent: Monday, December 13, 2021 12:00 PM
To: [email protected]
Subject: arv-tools not detecting USB3 camera
I have a USB3 Grasshopper3 GS3-U3-51S5C camera that arv-tools-0.8 is not detecting.
The GS3-U3-51S5C supports USB3 Vision v1.0,
OS: Redhat 8.4
{Aravis detects only my GigE cameras:}
{arv-tools with options does not list usb camera either}
[15:02:46.093] ?? interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
{The camera shows up in libusb and /dev/bus/usb, but is not found by arv-tool:}
kgofron@xf11id-m3:/epics/iocs/cam-aravis1$ lsusb
Bus 002 Device 003: ID 1e10:3300 Point Grey Research, Inc.
kgofron@xf11id-m3:/epics/iocs$ ls /dev/bus/usb/002/003
{USB camera is on bus 002 device 003}
Camera details:
kgofron@xf11id-m3:/dev/bus/usb/002$ usb-devices
T:  Bus=02 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#=  3 Spd=5000 MxCh= 0
D:  Ver= 3.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS= 9 #Cfgs=  1
P:  Vendor=1e10 ProdID=3300 Rev=00.00
S:  Manufacturer=Point Grey Research
S:  Product=Grasshopper3 GS3-U3-51S5C
S:  SerialNumber=0123EF71
C:  #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=896mA
I:  If#=0x0 Alt= 0 #EPs= 2 Cls=ef(misc ) Sub=05 Prot=00 Driver=(none)
I:  If#=0x1 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=01 Driver=(none)
I:  If#=0x2 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=02 Driver=(none)
USB support is installed:
libusb-devel.x86_64
Any suggestions about this problem?
Kazimierz Gofron
arv-tools not detecting USB3 camera Gofron, Kazimierz via Tech-talk
RE: arv-tools not detecting USB3 camera Engbretson, Mark S. via Tech-talk
Re: arv-tools not detecting USB3 camera Gofron, Kazimierz via Tech-talk
RE: arv-tools not detecting USB3 camera Mark Rivers via Tech-talk
RE: arv-tools not detecting USB3 camera Li, Ji via Tech-talk
Prev: Re: arv-tools not detecting USB3 camera Michael Davidsaver via Tech-talk
Next: Re: [Ext] RE: ADEiger Stream stop zmq? Jesse Hopkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: arv-tools not detecting USB3 camera Li, Ji via Tech-talk
Next: Re: arv-tools not detecting USB3 camera Michael Davidsaver via Tech-talk
