1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS_DB_INCLUDE_PATH
To: Ralph Lange <[email protected]>
Date: Thu, 16 Dec 2021 10:55:35 -0800
Simon described clearly, and his explanation is excellent for e3, and that is my design concept for e3 also according to PSI experiences.
I don't know what the current policy of e3 has. But, the original policy which I designed was to convert all substitutes files to a single DB file during the installation procedure. So, a startup script only uses several DB files instead of any others. It allows users to use other formats, but no recommendation for this. All version controls for DB and substitutes files are in standard git version controls procedure. Different versions of each module and IOC will have different DB files for production and installation.
This policy, I believe, could remove these potential issues on the DB file versioning and substitution files.
I replied to this discussion because I don't think I explained this policy enough to Timo, Simon, or others at ESS. But everything was my original design and implementation.
HTH,
Han
On Thu, Dec 16, 2021 at 10:40 AM Ralph Lange via Tech-talk <[email protected]> wrote:
On Thu, 16 Dec 2021 at 09:34, Simon Rose <[email protected]> wrote:
In e3, the database files that are installed with a module will always be installed at the location $(module_DB) (an environment variable set by require when loading a module).
In general the e3 team at ESS recommends referencing the database file paths explicitly as opposed to relying on or manipulating EPICS_DB_INCLUDE_PATH; given that there are many modules installed together, it seems you could end up loading the "wrong" one in a possibly annoying to trace way.
Similarly, if database files are located relative to the current startup command, it would be best to explicitly reference the file as
dbLoadRecords($(E3_CMD_TOP)/path/to/database.db)
so as to remove ambiguity.
The more problematic case are substitutions files: the name (and possibly full path) of the template database are inside the substitutions file, which itself could be under version control from a different shared support module...
Cheers,
~Ralph
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Michael Davidsaver via Tech-talk
RE: EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Simon Rose via Tech-talk
Prev: Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
Next: RE: ADVimba memory leak ? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Camera parameters not writable in ADAravis Gofron, Kazimierz via Tech-talk
