I added - system "python your-python-file.py &" to my st.cmd file and
when the ioc starts, the python scripts start! Thank you for the
suggestion.
However when I stop the ioc, the python scripts remain running in the
background. How can I get the python scripts to stop when the ioc is
stopped?
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Dana 06.01.2022 18:35, Hu, Yong je napisao(la):
Another way automatically start the python script with the ioc, simply
add this kind of line at the end of your IOC’s st.cmd:
However, you need include “system.dbd” in your IOC application. In
your application’s src/Makefile, add this kind of line:
yourIOCApplicationName_DBD += system.dbd
FROM: Tech-talk <[email protected]> on behalf of GAGET
Alexis via Tech-talk <[email protected]>
DATE: Thursday, January 6, 2022 at 12:11 PM
TO: Donny Domagoj Cosic <[email protected]>,
[email protected] <[email protected]>
SUBJECT: RE: Start IOC automatically at boot
"Is there a way to automatically start the python script with the
ioc?"
-> You can simply use procServ as well to execute your python script
DE : Tech-talk <[email protected]> de la part de Donny
Domagoj Cosic via Tech-talk <[email protected]>
ENVOYÉ : mercredi 5 janvier 2022 21:30:07
À : Ralph Lange via Tech-talk
OBJET : Start IOC automatically at boot
Happy new year!
I am trying to install systemd-softioc (procServ) as outlines here
https://github.com/NSLS-II/systemd-softioc [1]. I followed the
instructions
and successfully installed it on my Raspberry Pi. I installed the IOC
and can manually start the softioc, however I am not able to start
the
IOC using manage-iocs. I get the following output:
softioc@raspberrypi:/epics/iocs/testIOC2$ sudo manage-iocs start
testIOC2
Starting the IOC 'testIOC2' ...
Failed to start the IOC 'testIOC2'; type 'sudo journalctl -xe' for
details.
Below is my config file and output from the journalctl
Config
NAME=testIOC2
PORT=4053
HOST=raspberrypi
USER=softioc
CHDIR="/epics/iocs/testIOC2/iocBoot/ioctestIOC2"
EXEC="$CHDIR/st.cmd"
Output from journalctl
Jan 05 21:11:29 raspberrypi sudo[13371]: softioc : TTY=pts/0 ;
PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/manage-iocs
install testIOC2
Jan 05 21:11:29 raspberrypi sudo[13371]: pam_unix(sudo:session):
session
opened for user root by (uid=0)
session
closed for user root
Jan 05 21:11:43 raspberrypi sudo[13423]: softioc : TTY=pts/0 ;
start testIOC2
Jan 05 21:11:43 raspberrypi sudo[13423]: pam_unix(sudo:session):
session
Jan 05 21:11:43 raspberrypi systemd[1]: Reloading.
Jan 05 21:11:43 raspberrypi systemd[1]: [email protected]:
Current command vanished from the unit file, execution of the command
list won't be resume
Jan 05 21:11:43 raspberrypi systemd[1]: plexmediaserver.service:
Current
command vanished from the unit file, execution of the command list
won't
be resumed.
Jan 05 21:11:44 raspberrypi systemd[1]: Condition check resulted in
IOC
testIOC2 via procServ being skipped.
-- Subject: A start job for unit softioc-testIOC2.service has
finished
successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support [2]
-- A start job for unit softioc-testIOC2.service has finished
successfully.
-- The job identifier is 1803.
Jan 05 21:11:45 raspberrypi sudo[13423]: pam_unix(sudo:session):
session
Jan 05 21:11:54 raspberrypi sudo[13487]: softioc : TTY=pts/0 ;
PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/journalctl
-xe
Jan 05 21:11:54 raspberrypi sudo[13487]: pam_unix(sudo:session):
session
The softioc testIOC2 contains a few records which get updated from a
python script. Which brings me to my next questions. Is there a way
to
automatically start the python script with the ioc?
Thank you very much for your help,
Regards
Donny Domagoj Cosic
T: +385 1 4561 041 | @: [email protected] | www.irb.hr [3]
Links:
[1] https://github.com/NSLS-II/systemd-softioc
[2]
https://urldefense.com/v3/__https:/www.debian.org/support__;!!P4SdNyxKAPE!XScIVOM_CZDyHbp9c76gj4WzN_hFVrfqEqfAzjKK-hfgXnNgknPHzlsNS57f$
[3]
https://urldefense.com/v3/__http:/www.irb.hr__;!!P4SdNyxKAPE!XScIVOM_CZDyHbp9c76gj4WzN_hFVrfqEqfAzjKK-hfgXnNgknPHznuurVW7$
- Re: Start IOC automatically at boot Hu, Yong via Tech-talk
- Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
- RE: Start IOC automatically at boot GAGET Alexis via Tech-talk
Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
