1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Calling the streamReload IOC Shell function within C
From: "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 24 Jan 2022 08:18:08 +0000
Hi Dirk,
Since there isn't a function prototype for streamReload, do you recommend that I manually add it into devStream.h? gcc isn't liking the fact that I am calling to streamReload, because there is no prototype.
Andy
-----Original Message-----
Sent: Saturday, January 22, 2022 3:04 AM
To: EPICS tech-talk <tech-talk at aps.anl.gov>; Wang, Andrew <wang126 at llnl.gov>
Cc: Michael Davidsaver <mdavidsaver at gmail.com>
Subject: Re: Calling the streamReload IOC Shell function within C
Hi Andy
You can call extern „C“ long streamReload(const char* recordname) directly from C/C++. If NULL is passed for recordname, then all StreamDevice records reload. If a record is in the middle of processing, the running protocol is aborted and the record goes to INVALID alarm until the next processing.
It seems I have forgotten to put the function prototype into devStream.h. Will be done in the next release.
Dirk
> Am 22.01.2022 um 06:08 schrieb Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>:
> On 1/21/22 19:39, Wang, Andrew via Tech-talk wrote:
>> This is a far-fetched question, but I was wondering whether there is a possibility of executing streamReload, or a similar functionality, within a C function. The reason why I ask is because I saw within this Github link (https://urldefense.us/v3/__https://github.com/epics-modules/ioczed/blob/master/zzzApp/Db/streamExample.db__;!!G2kpM7uM-TzIFchu!gjnSZo93VcnoDkmziao7QLSXtfmZDUg0hZ5hqdkj-M2oKQch9GQRdAvkPjUS4spw6a4$  <https://urldefense.us/v3/__https://github.com/epics-modules/ioczed/blob/master/zzzApp/Db/streamExample.db__;!!G2kpM7uM-TzIFchu!gjnSZo93VcnoDkmziao7QLSXtfmZDUg0hZ5hqdkj-M2oKQch9GQRdAvkPjUS4spw6a4$ >) that the SUB record calls streamReload. However, I couldn’t locate the source code for that, so I am not entirely sure how it is used and what its arguments are. Thoughts?
> The registrar code adding both the function callable from subRecord as
> well as iocsh.
> https://urldefense.us/v3/__https://github.com/paulscherrerinstitute/St
> reamDevice/blob/dfbd308d4602e7cb99d7f60ddf35909a70f41c4f/src/StreamEpi
> cs.cc*L297-L307__;Iw!!G2kpM7uM-TzIFchu!gjnSZo93VcnoDkmziao7QLSXtfmZDUg
> 0hZ5hqdkj-M2oKQch9GQRdAvkPjUS5UlYp3c$
> So you could do something like
>> iocshCmd("streamReload");
> cf. iocsh.h from Base.
> Since it is already callable from a subRecord I assume it is
> thread-safe.
AW: Calling the streamReload IOC Shell function within C Zimoch Dirk (PSI) via Tech-talk
Calling the streamReload IOC Shell function within C Wang, Andrew via Tech-talk
Re: Calling the streamReload IOC Shell function within C Michael Davidsaver via Tech-talk
Re: Calling the streamReload IOC Shell function within C Zimoch Dirk (PSI) via Tech-talk
Prev: Re: mrfioc2-PCI device Configuration Michael Davidsaver via Tech-talk
Next: AW: Calling the streamReload IOC Shell function within C Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Calling the streamReload IOC Shell function within C Zimoch Dirk (PSI) via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
