1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Epics 7 Alias options question
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Thu, 3 Mar 2022 02:15:01 +0000
Hi All,
I was reading through some old tech talk posts about how aliases work and had a few questions.  The problem I am trying to solve is to add some level of flexibility to a piece of equipment’s PV names.  I thought the alias might be a runtime option where the operator could input to a CS Studio box a name such as “Water Level 1” which is saving to a PV “SCOPE1:DIG1:CH1.ALIAS” (after reading I don’t think this is possible though?).  Currently I have each digitizer channel hardcoded with a signal name “SCOPE1:DIG1:Water_Level_1”.  The idea was to be able to rename the channels of a digitizer given what gets hooked up to each channel during runtime of the system.
From exploring tech talk posts are these the only ways to do the aliases
  1. Use the db command for aliases to load an alias file, is this similar to the dbLoadRecord used in the st.cmd file?
  2. Add an alias file into my gateway
Prev: StreamDevice 刘晓敏 via Tech-talk
Next: Re: StreamDevice Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: 回复: StreamDevice Zimoch Dirk (PSI) via Tech-talk
Next: RHEL8 as an NFS server for RTEMS Hu, Yong via Tech-talk
