1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: 回复: StreamDevice
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 8 Mar 2022 13:28:30 +0000
Hello Xiaomin,
You cannot read a string into an 'ai' record. That record is for floating point numbers.
Try a 'stringin' record instead.
Dirk
On Tue, 2022-03-08 at 16:29 +0800, liuxiaomin via Tech-talk wrote:
> Hi Mark,
> Thank you for helping me solve the previous problem.
> I want to execute a *IDN? command which returns the instrument’s identification string,
> The db files is as follows:
> record(ai, "$(user):xh") {
>   field(DTYP, "stream")
>   field(SCAN, "1 second")
>   field(INP, "@sd.proto DEVICENAME CAT1")
> The proto files is as follows:
> DEVICENAME{
>     out "*IDN?";
>     in "%s";
> When I execute the st.cmd file,it shows no error, but when I type caget, it shows 0.I think it should returns a string
> with the following format: Agilent Technologies,53230A,MY58060118,02.09-1731.8935-1.19-4.16-127-159-35. The
> description of the command of *IDN? is in the attachment.
> How can I solve this problem?
> Thanks,
> Xiaomin
> 发件人: Mark Rivers
> 发送时间: 2022年3月3日 10:28
> 收件人: [email protected]; 刘晓敏
> 主题: Re: StreamDevice
> Hi Xiaomin,
> I am confused.  You have this which implies that the external device for stream is at IP address 169.254.2.30
> drvAsynIPPortConfigure("CAT1","169.254.2.30:5025",0,0,1)
> But your IOC has this:
> EPICS_CA_ADDR_LIST: 169.254.2.30:5068
> Your client host has this:
> EPICS_CA_ADDR_LIST=169.254.2.30:5068
> So your IOC, client machine, and external device all have the same IP address?
> If this is correct, then your EPICS IOC and the EPICS client (caget) are on the same subnet.  Then just don't define
> EPICS_CA_ADDR_LIST or EPICS_CA_AUTO_ADDR_LIST.  It should find the PV fine.
> Mark
> From: Tech-talk <[email protected]> on behalf of 刘晓敏 via Tech-talk <[email protected]>
> Sent: Wednesday, March 2, 2022 7:59 PM
> To: [email protected] <[email protected]>
> Subject: StreamDevice
> Hi,
> I am trying to use StreamDevice on debian system to control device, the device is universal frequency counter/timer.
> When I execute the st.cmd file,it shows no error, but when I type caget, it shows pv name not found:
> #!../../bin/linux-x86_64/sd
> < envPaths
> epicsEnvSet("IOC","iocsd")
> epicsEnvSet("TOP","/home/iocusr/sd")
> epicsEnvSet("MODULES","/opt/epics/base/../modules")
> epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
> epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
> epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
> epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
> epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
> epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
> epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
> epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
> epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
> epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
> epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
> epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
> epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
> epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
> epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
> epicsEnvSet("EPICS_BASE","/opt/epics/base")
> epicsEnvSet("EPICS_CA_SERVER_PORT", 5068)
> epicsEnvSet("IOCNAME","sd")
> cd "/home/iocusr/sd"
> dbLoadDatabase "dbd/sd.dbd"
> sd_registerRecordDeviceDriver pdbbase
> dbLoadRecords "db/sd.db", "user=sd"
> epicsEnvSet("STREAM_PROTOCOL_PATH", ".:../../db")
> cd "/home/iocusr/sd/iocBoot/iocsd"
> iocInit
> Starting iocInit
> sevr=info s7plcInit: no stations configured
> iocRun: All initialization complete
> epics> dbl
> sd:xh
> caget sd:xh
> Channel connect timed out: 'sd:xh' not found.
> epics> asynReport 1
> CAT1 multiDevice:No canBlock:Yes autoConnect:Yes
>     enabled:Yes connected:Yes numberConnects 1
>     nDevices 0 nQueued 0 blocked:No
>     asynManagerLock:No synchronousLock:No
>     exceptionActive:No exceptionUsers 1 exceptionNotifys 0
>     traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
>     Port 169.254.2.30:5025: Connected
> DEVICENAME{
>     out "*IDN?";
>     in "%f";
> The output of the epicsPrtEnvParams command at the IOC prompt is as follows:
> epicsPrtEnvParams
> EPICS_CA_CONN_TMO: 30.0
> EPICS_CA_AUTO_ADDR_LIST: NO
> EPICS_CA_REPEATER_PORT: 5065
> EPICS_CA_SERVER_PORT: 5068
> EPICS_CA_MAX_ARRAY_BYTES: 16384
> EPICS_CA_AUTO_ARRAY_BYTES: YES
> EPICS_CA_MAX_SEARCH_PERIOD: 300.0
> EPICS_CA_NAME_SERVERS is undefined
> EPICS_CA_MCAST_TTL: 1
> EPICS_CAS_INTF_ADDR_LIST is undefined
> EPICS_CAS_IGNORE_ADDR_LIST is undefined
> EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
> EPICS_CAS_BEACON_ADDR_LIST is undefined
> EPICS_CAS_SERVER_PORT is undefined
> EPICS_CA_BEACON_PERIOD: 15.0
> EPICS_CAS_BEACON_PERIOD is undefined
> EPICS_CAS_BEACON_PORT is undefined
> EPICS_BUILD_COMPILER_CLASS: gcc
> EPICS_BUILD_OS_CLASS: Linux
> EPICS_BUILD_TARGET_ARCH: linux-x86_64
> EPICS_TZ: CST6CDT,M3.2.0/2,M11.1.0/2
> EPICS_TS_NTP_INET is undefined
> EPICS_IOC_IGNORE_SERVERS is undefined
> EPICS_IOC_LOG_PORT: 7004
> EPICS_IOC_LOG_INET is undefined
> EPICS_IOC_LOG_FILE_LIMIT: 1000000
> EPICS_IOC_LOG_FILE_NAME is undefined
> EPICS_IOC_LOG_FILE_COMMAND is undefined
> IOCSH_PS1: epics>
> IOCSH_HISTSIZE: 50
> IOCSH_HISTEDIT_DISABLE is undefined
> epics>
> The output of theprintenv | grep EPICS command at the shell prompt where  running caput is as follows:
> EPICS_HOST_ARCH=linux-x86_64
> EPICS_CA_AUTO_ADDR_LIST=NO
> EPICS_BASE=/opt/epics/base
> The description of the command of *IDN? is in the attachment.
> I don't know what's wrong, how can I solve this problem?
> Thanks,
> Xiaomin
StreamDevice 刘晓敏 via Tech-talk
Re: StreamDevice Mark Rivers via Tech-talk
回复: StreamDevice liuxiaomin via Tech-talk
Prev: RE: Tech-talk Digest, Vol 16, Issue 101 Rebecca Harding - STFC UKRI via Tech-talk
Next: Re: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Ashish Sharma via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: 回复: StreamDevice liuxiaomin via Tech-talk
Next: Epics 7 Alias options question Manoussakis, Adamandios via Tech-talk
