1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: 回复: StreamDevice
From: liuxiaomin via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 8 Mar 2022 16:29:52 +0800
Hi Mark,
Thank you for helping me solve the previous problem.
I want to execute a *IDN? command which returns the instrument’s identification string,
The db files is as follows:
record(ai, "$(user):xh") {
  field(DTYP, "stream")
  field(SCAN, "1 second")
  field(INP, "@sd.proto DEVICENAME CAT1")
The proto files is as follows:
DEVICENAME{
    out "*IDN?";
    in "%s";
When I execute the st.cmd file,it shows no error, but when I type caget, it shows 0.I think it should returns a string with the following format: Agilent Technologies,53230A,MY58060118,02.09-1731.8935-1.19-4.16-127-159-35. The description of the command of *IDN is in the attachment.
How can I solve this problem?
Xiaomin
发件人: Mark Rivers
发送时间: 202233 10:28
收件人: tech-talk at aps.anl.gov; 刘晓敏
主题: Re: StreamDevice
Hi Xiaomin,
I am confused.  You have this which implies that the external device for stream is at IP address 169.254.2.30
drvAsynIPPortConfigure("CAT1","169.254.2.30:5025",0,0,1)
But your IOC has this:
EPICS_CA_ADDR_LIST: 169.254.2.30:5068
Your client host has this:
EPICS_CA_ADDR_LIST=169.254.2.30:5068
So your IOC, client machine, and external device all have the same IP address?
If this is correct, then your EPICS IOC and the EPICS client (caget) are on the same subnet.  Then just don't define EPICS_CA_ADDR_LIST or EPICS_CA_AUTO_ADDR_LIST.  It should find the PV fine.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of 刘晓敏 via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, March 2, 2022 7:59 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: StreamDevice
I am trying to use StreamDevice on debian system to control device, the device is universal frequency counter/timer.
When I execute the st.cmd file,it shows no error, but when I type caget, it shows pv name not found:
#!../../bin/linux-x86_64/sd
< envPaths
epicsEnvSet("IOC","iocsd")
epicsEnvSet("TOP","/home/iocusr/sd")
epicsEnvSet("MODULES","/opt/epics/base/../modules")
epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("EPICS_CA_SERVER_PORT", 5068)
epicsEnvSet("IOCNAME","sd")
cd "/home/iocusr/sd"
dbLoadDatabase "dbd/sd.dbd"
sd_registerRecordDeviceDriver pdbbase
dbLoadRecords "db/sd.db", "user=sd"
epicsEnvSet("STREAM_PROTOCOL_PATH", ".:../../db")
cd "/home/iocusr/sd/iocBoot/iocsd"
iocInit
Starting iocInit
sevr=info s7plcInit: no stations configured
epics> dbl
sd:xh
caget sd:xh
Channel connect timed out: 'sd:xh' not found.
epics> asynReport 1
CAT1 multiDevice:No canBlock:Yes autoConnect:Yes
    enabled:Yes connected:Yes numberConnects 1
    nDevices 0 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 1 exceptionNotifys 0
    traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
    Port 169.254.2.30:5025: Connected
DEVICENAME{
    out "*IDN?";
    in "%f";
The output of the epicsPrtEnvParams command at the IOC prompt is as follows:
epicsPrtEnvParams
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_AUTO_ADDR_LIST: NO
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5068
EPICS_CA_MAX_ARRAY_BYTES: 16384
EPICS_CA_AUTO_ARRAY_BYTES: YES
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CA_MCAST_TTL: 1
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_BUILD_COMPILER_CLASS: gcc
EPICS_BUILD_OS_CLASS: Linux
EPICS_BUILD_TARGET_ARCH: linux-x86_64
EPICS_TZ: CST6CDT,M3.2.0/2,M11.1.0/2
EPICS_TS_NTP_INET is undefined
EPICS_IOC_IGNORE_SERVERS is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
IOCSH_PS1: epics>
IOCSH_HISTSIZE: 50
IOCSH_HISTEDIT_DISABLE is undefined
epics>
The output of theprintenv | grep EPICS command at the shell prompt where  running caput is as follows:
EPICS_HOST_ARCH=linux-x86_64
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_BASE=/opt/epics/base
I don't know what's wrong, how can I solve this problem?
Xiaomin
Re: 回复: StreamDevice Zimoch Dirk (PSI) via Tech-talk
StreamDevice 刘晓敏 via Tech-talk
Re: StreamDevice Mark Rivers via Tech-talk
Prev: Timestamp test questions on Linux gjzhai--- via Tech-talk
Next: RE: Tech-talk Digest, Vol 16, Issue 101 Rebecca Harding - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: StreamDevice Mark Rivers via Tech-talk
Next: Re: 回复: StreamDevice Zimoch Dirk (PSI) via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
