1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: phoebus: write waveform PV
From: Gabriel Fedel via Tech-talk <[email protected]>
To: <[email protected]>
Date: Mon, 11 Apr 2022 14:03:00 +0200
Hi William,
the way I normally do this is using the array from jarray:
from jarray import array
pvs[0].setValue(array(yourlist, 'd'))
On the example, your list would be the variable yourlist.
Cheers
On 4/11/22 13:57, William Kirstaedter via Tech-talk wrote:
I have a short question:
I have a small embedded python script that generates a waveform of 4096 points from a user-given formula. (i.e. sin(t))
I want to write that waveform data to the corresponding PV.
But phoebus / Jython complains about not being able to write a pyList Datatype ...
Caused by: java.lang.Exception: Cannot handle type org.python.core.PyList
How can I convert my python list object to a DoubleArray?
I tried to import VDoubleArray but its abstract ...
William Kirstaedter (PP&B) 	Fritz-Haber-Institut der MPG
Faradayweg 4-6 	14195 Berlin
Tel: 030 8413 5405 	Mail: [email protected]
Gabriel Fedel
Control System Engineer / Integrated Control System Division
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 72 179 23 01
E-mail: [email protected]
ess.eu
Re: phoebus: write waveform PV William Kirstaedter via Tech-talk
Prev: phoebus: write waveform PV William Kirstaedter via Tech-talk
Next: EPICS areaDetector plugin & phoebus Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: phoebus: write waveform PV William Kirstaedter via Tech-talk
