... works.
thanks alot!
| William Kirstaedter (PP&B) |
Fritz-Haber-Institut der MPG |
| Faradayweg 4-6 |
14195 Berlin |
| Tel: 030 8413 5405 |
Mail: [email protected] |
Am 11.04.2022 um 14:03 schrieb Gabriel
Fedel via Tech-talk:
Hi William,
the way I normally do this is using the array from jarray:
from jarray import array
pvs[0].setValue(array(yourlist, 'd'))
On the example, your list would be the variable yourlist.
Cheers
On 4/11/22 13:57, William Kirstaedter via Tech-talk wrote:
I have a short question:
I have a small embedded python script that generates a waveform
of 4096 points from a user-given formula. (i.e. sin(t))
I want to write that waveform data to the corresponding PV.
But phoebus / Jython complains about not being able to write a
pyList Datatype ...
Caused by: java.lang.Exception: Cannot handle type
org.python.core.PyList
How can I convert my python list object to a DoubleArray?
I tried to import VDoubleArray but its abstract ...
William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG
Faradayweg 4-6 14195 Berlin
Tel: 030 8413 5405 Mail: [email protected]
smime.p7s
Description: S/MIME Cryptographic Signature
- phoebus: write waveform PV William Kirstaedter via Tech-talk
- Re: phoebus: write waveform PV Gabriel Fedel via Tech-talk
Re: EPICS areaDetector plugin & phoebus Mark Rivers via Tech-talk
RE: EPICS areaDetector plugin & phoebus Pearson, Matthew via Tech-talk
<2022>
2025
2026
EPICS areaDetector plugin & phoebus Jörn Dreyer via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
