1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: EPICS areaDetector plugin & phoebus
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 11 Apr 2022 14:39:05 +0200
Hi ,
for a project we want to use openPMD (openpmd.org) as storage format. Has
anybody been working on a areaDetector plugin using openPMD?
In the end we want to use ADIOS2 (adios2.readthedocs.io/en/latest.html) to
transport the data with high speed to a remote server for storage and
processing. Remote server will be used because then the offline analysis can
start immediately without waiting for the data to be copied from the iOC
server to the compute node.
The task is to handle 64Mpx images from a CCD@16bit at 10Hz. As the camera has
USB3.0 as interface for readout, it's clear that we have to use binning of 4
or even 6 to get this frames per second.
If we would implement all the necesarry analysis code as plugins for
areaDetector, what would be the maximum frame rate that can be reliably
displayed in e.g. phoebus? And is there a difference between CA and pva
protocol?
Jörn Dreyer
Re: EPICS areaDetector plugin & phoebus Mark Rivers via Tech-talk
Prev: Re: phoebus: write waveform PV Gabriel Fedel via Tech-talk
Next: ADAravis PoolUsedBuffers Steve Kinder - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: phoebus: write waveform PV William Kirstaedter via Tech-talk
Next: Re: EPICS areaDetector plugin & phoebus Mark Rivers via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
