Ø
As far as I know, implementations of compression/decompression like the one for ImageJ call out to native libraries
That is true. But the decompression libraries are all built in ADSupport in a way that makes them easy to call from other applications and languages, including Java. They are called from ImageJ, and also from the HDF5 library via its
run-time plugin mechanism. This means that HDF5 applications do not need to be linked with the decompressors, they can find and load them at run-time.
Because they are built from source in ADSupport, there are minimal dependencies on OS packages.
On Behalf Of Kasemir, Kay via Tech-talk
Sent: Monday, April 11, 2022 10:30 AM
To: 'tech-talk at aps.anl.gov' <tech-talk at aps.anl.gov>
Subject: Re: EPICS areaDetector plugin & phoebus
> I’ve forgotten if CSS/Phoebus supports compressed PVA NTNDArray objects, but that would help a lot when visualizing large arrays.
- EPICS areaDetector plugin & phoebus Jörn Dreyer via Tech-talk
- Re: EPICS areaDetector plugin & phoebus Mark Rivers via Tech-talk
- RE: EPICS areaDetector plugin & phoebus Pearson, Matthew via Tech-talk
- Re: EPICS areaDetector plugin & phoebus Kasemir, Kay via Tech-talk
Synchronizing external changes to target instrument with EPICS Wang, Andrew via Tech-talk
<2022>
2025
ADAravis PoolUsedBuffers Steve Kinder - STFC UKRI via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
