1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Synchronizing external changes to target instrument with EPICS
From: "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 11 Apr 2022 17:14:58 +0000
Hi all,
Long story short, we have an instrument that we wrote EPICS drivers for. The instrument in question also has a webpage, where all its settings are accessible. The goal is for the EPICS drivers to be updated when a modification is made to the webpage.
Suppose we have a setting on the instrument that allows us to adjust its voltage output. The EPICS drivers would contain a “getter” and “setter” record of the following.
record(ao, “voltage_set”)
                field(DTYP, “stream”)
                field(OUT,  “@commands.proto setVoltage 4000”)
record(ai, “voltage_get”)
                field(INP,  “@commands.proto getVoltage 4000”)
If I adjusted the voltage through the webpage, then I would also like the updated voltage to show up in “voltage_set”, like what is done through the @init protocol during initialization. I was thinking of doing this via “streamReload” in a subroutine record, which gets processed every ~5 seconds or so. Is that a viable solution or is there a better way of going about it?
Thank you,
Andy
Purple ribbon awareness
Prev: RE: EPICS areaDetector plugin & phoebus Mark Rivers via Tech-talk
Next: Process linux system file values as PVs Kunjir, Shriraj via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: ADAravis PoolUsedBuffers Steve Kinder - STFC UKRI via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
