1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Alignment mode for AreaDetectors?
From: "Miceli, Antonino via Tech-talk" <[email protected]>
To: "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Thu, 12 May 2022 16:30:42 +0000
The Pilatus detector had a popular mode called alignment which came with the detector SDK; essentially this mode would overwrite to the same file and continue until the stop button was pressed.
Is there a clean/easy way to emulate this for other areadetectors? (I know I can disable all the file writing plugins.)
Nino
RE: Alignment mode for AreaDetectors? Engbretson, Mark S. via Tech-talk
RE: Alignment mode for AreaDetectors? Mark Rivers via Tech-talk
Prev: Re: PI controller C-887 Kevin Peterson via Tech-talk
Next: RE: Alignment mode for AreaDetectors? Engbretson, Mark S. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
