1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Alignment mode for AreaDetectors?
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Miceli, Antonino" <amiceli at anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 12 May 2022 17:12:29 +0000
Hi Nino,
Ø  The Pilatus detector had a popular mode called alignment which came with the detector SDK; essentially this mode would overwrite to the same file and continue until the stop button was pressed.
That mode is not part of the SDK, it was something I created in the ADPilatus driver.  All it does is to set NumImages=1 and to tell camserver to keep writing to the same file called “alignment.tif”.  It reads back the data from alignment.tif and does callbacks to all registered plugins, just as for regular data collection mode.
Ø  Is there a clean/easy way to emulate this for other areadetectors? (I know I can disable all the file writing plugins.)
There is no need to disable the file writing plugins, although you would probably want to disable AutoSave in each file plugin if that is enabled.  But that is no different than the ADPilatus in alignment mode: if AutoSave is enabled for a file plugin when using the ADPilatus driver then files will be written even in alignment mode.
Perhaps I am not understanding the question.  What is it that works for you with the ADPilatus in alignment mode that does not work with other detectors, and which detector in particular are you asking about? As Mark E. said if you are using a driver that always writes files then you can just disable auto-increment to avoid creating many files.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Miceli, Antonino via Tech-talk
Sent: Thursday, May 12, 2022 11:31 AM
To: tech-talk at aps.anl.gov >> EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Alignment mode for AreaDetectors?
Nino
Re: Alignment mode for AreaDetectors? Miceli, Antonino via Tech-talk
Prev: RE: Alignment mode for AreaDetectors? Engbretson, Mark S. via Tech-talk
Next: Re: Alignment mode for AreaDetectors? Miceli, Antonino via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
