1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Alignment mode for AreaDetectors?
From: "Engbretson, Mark S. via Tech-talk" <tech-talk at aps.anl.gov>
To: "Miceli, Antonino" <amiceli at anl.gov>, "tech-talk at aps.anl.gov >> EPICS Tech Talk" <tech-talk at aps.anl.gov>
Date: Thu, 12 May 2022 16:54:14 +0000
Don’t turn on file number auto-increment?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Miceli, Antonino via Tech-talk
Sent: Thursday, May 12, 2022 11:31 AM
To: tech-talk at aps.anl.gov >> EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Alignment mode for AreaDetectors?
The Pilatus detector had a popular mode called alignment which came with the detector SDK; essentially this mode would overwrite to the same file and continue until the stop button was pressed.
Is there a clean/easy way to emulate this for other areadetectors? (I know I can disable all the file writing plugins.)
Nino
Alignment mode for AreaDetectors? Miceli, Antonino via Tech-talk
Prev: Alignment mode for AreaDetectors? Miceli, Antonino via Tech-talk
Next: RE: Alignment mode for AreaDetectors? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
