Hey all,
we have a Huber Unistat chiller with "PilotOne" Controller. The
Controller has a modbus/TCP interface.
For reading out the status of the chiller, I have set the SCAN
field of the first input record and use a chain of forward links
to all the other input records.
Sometimes I can see messages of the following type in my IOC:
epics> 2022/05/19 16:46:36.370 drvModbusAsyn::doModbusIO port
chillerReadReg error calling writeRead, error=PilotONE-187144:502
TCP timeout: Resource temporarily unavailable, nwrite=6/6, nread=0
2022/05/19 16:46:36.370 SCATTERCHAMBER:COOLING:FillLevel
devAsynInt32::processCallbackInput process read error
2022/05/19 16:46:36.469 drvModbusAsyn::doModbusIO port
chillerReadReg writeRead status back to normal having had 1
errors, nwrite=6/6, nread=4
My guess is, the forward links are processed "too fast" for the
controller and it cannot reply.
Is this plausible or could this error messages have a different
cause?
What would be a good idea to "slow down" the readout?
Using a seq record with delays instead of forward links?
Another issue, that I have is writing the Setpoint of the device.
From the manual:
The client sends the following request to
the Modbus slave:
00 02 00 00 00 06 FF 06 00 00 05 DC
The command is made up as follows:
00 02 TID (any number that can be used to assign a response
to a query)
00 00 PID (always 0x0000)
00 06 The message length is 6 bytes. Of these, 1 byte is used
for the unit identifier, 1 byte
for the function code, 2 bytes for the PB address and
2 bytes are used for the value
to be written.
FF Unit identifier (UID, always 0xFF)
06 Function code 0x06 is used for Writing Single Holding
Registers
00 00 PB address (vSP 0x00)
05 DC The setpoint temperature is to be set to 15.00 °C. The
value 1500 equals 0x05DC in
hex notation.
The Modbus slave returns the following response:
For me it looks like this:
epics> dbpf SCATTERCHAMBER:COOLING:Setpoint 15
DBF_DOUBLE: 15
2022/05/19 17:04:09.078 drvModbusAsyn::doModbusIO port
chillerWriteReg WRITE_SINGLE_REGISTER address=00 value=0x0
epics> 2022/05/19 17:04:09.078 PilotONE-187144:502 TCP
write 12
a2 3e 00 00 00 06 ff 06 00 00 00 00
2022/05/19 17:04:09.078 PilotONE-187144:502 TCP read 0
2022/05/19 17:04:09.079 drvModbusAsyn::doModbusIO port
chillerWriteReg called pasynOctetSyncIO->writeRead,
status=3, requestSize=6, replySize=5, nwrite=6, nread=0,
eomReason=0
epics>
First, the value (15) is not send, instead 00 00 is send. Second
I do not get a reply from the device.
I load the driver with
drvAsynIPPortConfigure( "chiller", "PilotONE-187144:502 TCP", 0,
0, 0 )
modbusInterposeConfig( "chiller", 0, 300, 0 )
drvModbusAsynConfigure( "chillerWriteReg", "chiller", 0xff, 6,
-1, 1, "INT16", 0, "Huber PilotOne" )
The record looks
like this:
record( ao, "$(H):$(N):Setpoint" ) {
field( DTYP, "asynInt32" )
field( OUT, "@asyn($(PORT_W) 0x00)INT16" )
field( EGU, "degC" )
field( PREC, "2" )
field( ADEL, "1" )
field( MDEL, "1" )
field( ASLO, "100" )
field( AOFF, "0" )
Any idea what am I doing wrong here?
Thanks for your help,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
- RE: Modbus for Huber Pilotone Mark Rivers via Tech-talk
Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
<2022>
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
<2022>
