1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Issue or misunderstanding with long string support
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 1 Jun 2022 16:56:22 +0000
The issue with long strings documented in this tech-talk thread https://epics.anl.gov/tech-talk/2021/msg01491.php appears to be present in both base 7.0.5 and 7.0.6.  It is fixed in 7.0.6.1.
The main impact for us is that that the OPI screens in the synApps calc module do not work.  For us upgrading to 7.0.6.1 is not an option because of the vxWorks issues with base 7.0.6 and 7.0.6.1 described in another thread.  To use base 7.0.5 and work around the long string problem I have created a new base_7_fix branch in the synApps calc module: https://github.com/epics-modules/calc/tree/base_7_fix
The branch removes all of the final $ characters from the OPI screens.  This means they won’t be able to write strings longer than 40 characters, but at least they don’t only write the first character (!!!), which is what happens without this change on IOCs with base 7.0.5 and 7.0.6.
Sent: Tuesday, May 31, 2022 3:07 PM
To: tech-talk at aps.anl.gov
Subject: Issue or misunderstanding with long string support
Our IOCs are now all running base 7.0.5.  We see an issue with medm screens containing string files using PVs that end in a “$”.  We can only change the first character in the string.
This is easy to reproduce using the caput and cainfo clients from base 7.0.5 to a PV in an IOC running base 7.0.5.
cainfo without the $ modifier shows the field is a DBF_STRING.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/cainfo 13BMD:userTran20.CLCA
    State:            connected
    Host:             ioc13bmd.cars.aps.anl.gov:5064
    Access:           read, write
    Native data type: DBF_STRING
    Request type:     DBR_STRING
    Element count:    1
cainfo with the $ modifier shows the field is a DBF_CHAR of size 120
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/cainfo 13BMD:userTran20.CLCA$
    State:            connected
    Access:           read, write
    Native data type: DBF_CHAR
    Request type:     DBR_CHAR
    Element count:    120
A caput without the $ modifier works, but that would be limited to 40 characters.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput 13BMD:userTran20.CLCA "A+B"
Old : 13BMD:userTran20.CLCA
New : 13BMD:userTran20.CLCA          A+B
A caput with the $ modifier does not work, only the first character in the string was changed.  It should have changed from A+B to B+A, but instead it changed to B+B.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput -S 13BMD:userTran20.CLCA$ "B+A"
Old : 13BMD:userTran20.CLCA$ A+B
New : 13BMD:userTran20.CLCA$ B+B
I see the same issue when writing to the DESC field of an ao record.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput testAo_1.DESC "123"
Old : testAo_1.DESC                  H23
New : testAo_1.DESC                  123
When writing with the $ modifier it should have changed “123” to “321”, but instead it is “323”.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput -S testAo_1.DESC$ "321"
Old : testAo_1.DESC$ 123
New : testAo_1.DESC$ 323
Is this a bug, or am I misunderstanding how long strings are supposed to work?
This looks similar to this bug that is fixed in 7.0.6.1, but that says it was specific to the CALC field.  https://github.com/epics-base/epics-base/issues/194
Issue or misunderstanding with long string support Mark Rivers via Tech-talk
Prev: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Issue or misunderstanding with long string support Mark Rivers via Tech-talk
Next: Alarm-Server within a container Larregui, Julian via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
