1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Alarm-Server within a container
From: "Larregui, Julian via Tech-talk" <[email protected]>
Date: Wed, 1 Jun 2022 18:20:19 +0000
Hello,
As the subject says I'm trying to get the alarm-server working with phoebus.
I've already built the image and created the container. I can run zookeeper-server-start and kafka-server-start just fine.
The issue becomes when trying to create a topic. Usually it is met with this error:
Error while executing topic command : Timed out waiting for a node assignment. Call: createTopics
[2022-06-01 17:51:09,207] ERROR org.apache.kafka.common.errors.TimeoutException: Timed out waiting for a node assignment. Call: createTopics
 (kafka.admin.TopicCommand$)
My assumption is incorrectly setting up the server.properties file, but unsure what to set it at.
currently:
listeners=PLAINTEXT://localhost:9092
advertised.listeners=PLAINTEXT://localhost:9092
zookeeper.connect=localhost:2181
Any advice would be welcomed.
Thank you for your time,
Re: Alarm-Server within a container Jörn Dreyer via Tech-talk
AW: Alarm-Server within a container Gotz, Malte via Tech-talk
Prev: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: Issue or misunderstanding with long string support Mark Rivers via Tech-talk
Next: Re: Alarm-Server within a container Jörn Dreyer via Tech-talk
