Hi Julian,
I faced a similar problem when setting up the archiver running in a container.
The problem is that your process is in a separate network than the host. To
get that working I set up a EPICS gateway server on the host that transports
messages between the two networks.
Jörn
Am Mittwoch, 1. Juni 2022, 20:20:19 CEST schrieb Larregui, Julian via Tech-
talk:
> Hello,
> As the subject says I'm trying to get the alarm-server working with phoebus.
> I've already built the image and created the container. I can run
> zookeeper-server-start and kafka-server-start just fine.
> The issue becomes when trying to create a topic. Usually it is met with this
> error:
> Error while executing topic command : Timed out waiting for a node
> assignment. Call: createTopics [2022-06-01 17:51:09,207] ERROR
> org.apache.kafka.common.errors.TimeoutException: Timed out waiting for a
> node assignment. Call: createTopics (kafka.admin.TopicCommand$)
> My assumption is incorrectly setting up the server.properties file, but
> unsure what to set it at. currently:
> listeners=PLAINTEXT://localhost:9092
> advertised.listeners=PLAINTEXT://localhost:9092
> zookeeper.connect=localhost:2181
> Any advice would be welcomed.
> Thank you for your time,
- Alarm-Server within a container Larregui, Julian via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
<2022>
2025
AW: Alarm-Server within a container Gotz, Malte via Tech-talk
<2022>
2025
