Hi Julian,
I think you are right, your problem lies probably in the settings you mentioned. Advertising kafka as localhost, will only work if you are running everything from within the same container
or maybe have both kafka and zookeeper on the same container and run the create topic from the host machine. I found a lot of setups for kafka inside docker use two listeners: One for inside the docker network for inter broker communication + zookeeper, and
one bound to your host to communicate to the outside.
I found settings this up quite painful. Now, I have a docker compose that has been working well for me. It uses the wurstmeister kafka and zookeeper images. I disentangled it from the
rest of my mess and put it here:
https://gitlab.helmholtz-berlin.de/a2324/phoebus-alarm-docker. Maybe it is helpful to you or you might even use it as it. If you have any problems with that, I am happy to help.
Malte
Von: Tech-talk <tech-talk-bounces at aps.anl.gov> Im Auftrag von
Larregui, Julian via Tech-talk
Gesendet: Mittwoch, 1. Juni 2022 20:20
An: tech-talk at aps.anl.gov
Betreff: Alarm-Server within a container
As the subject says I'm trying to get the alarm-server working with phoebus.
I've already built the image and created the container. I can run zookeeper-server-start and kafka-server-start just fine.
The issue becomes when trying to create a topic. Usually it is met with this error:
Error while executing topic command : Timed out waiting for a node assignment. Call: createTopics
[2022-06-01 17:51:09,207] ERROR org.apache.kafka.common.errors.TimeoutException: Timed out waiting for a node assignment. Call: createTopics
(kafka.admin.TopicCommand$)
My assumption is incorrectly setting up the server.properties file, but unsure what to set it at.
listeners=PLAINTEXT://localhost:9092
advertised.listeners=PLAINTEXT://localhost:9092
zookeeper.connect=localhost:2181
Any advice would be welcomed.
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
- Alarm-Server within a container Larregui, Julian via Tech-talk
Monitoring sscan record fields. [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
stream feature which similar wireshark 网易邮件中心 via Tech-talk
<2022>
2025
Re: Alarm-Server within a container Jörn Dreyer via Tech-talk
Strange memory leak with ADAravis Abdalla Ahmad via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
