1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
To: Kevin Peterson <[email protected]>, Till Straumann <[email protected]>
Date: Thu, 9 Jun 2022 17:51:20 +0000
> I modified my python script to toggle the ao values between -0.5 and 5 and the A32 address is always -0.5:
That makes sense because -0.5 is the only value that maps to the A32 address space. -0.4 to +5.0 do not.
-----Original Message-----
Sent: Thursday, June 9, 2022 12:21 PM
To: Mark Rivers <[email protected]>; Till Straumann <[email protected]>
Cc: [email protected]
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
VME Bus Error accessing A32: 0xbfe00000
machine check
Exception next instruction address: 0x032dc280 Machine Status Register: 0x0008b032 Condition Register: 0x40000844
Task: 0x3576c20 "CAC-event"
0x3576c20 (CAC-event): task 0x3576c20 has had a failure and has been stopped.
0x3576c20 (CAC-event): The task has been terminated because it triggered an exception that raised the signal 10.
I can't run the Wind River workbench yet; I'm still waiting on IT to start the necessary license servers.
My VME has the VMETRO bus analyzer in it, but it has probably been a decade since I watched someone (Ron Sluiter) use it effectively.
Kevin
On 6/9/22 11:05, Mark Rivers via Tech-talk wrote:
> If the test program loops from -0.7 to -0.5 the VME bus error address
> is 0xbfe66664.  That is -0.6999988555908203 when interpreted as a
> double with that address as the most significant 32 bits.  That is
> within the now more restricted range of the output values.
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Kevin Peterson via Tech-talk
Prev: PVStructure vs Structure Madden, Timothy J. via Tech-talk
Next: Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Kevin Peterson via Tech-talk
