1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: PVStructure vs Structure
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "Madden, Timothy J." <tmadden at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 10 Jun 2022 14:49:21 +0000
I guess another reason for the PVData vs. PVField design was that pvDataCPP and pvDataJava aimed to have almost exactly the same API for both C++ and Java, which gives you the lowest common denominator of both languages.
In Java, there is runtime type info. Given any Object, you can check if it's instanceof PVStructure or PVString or ...
With plain C, you can't check the type of a void *. With C++, there is now runtime type info, but I assume the safest approach was a DIY type info API that allows you to check if the data read from a PV is a PVStructure or PVStructureArray or ...
-Kay
Sent: Friday, June 10, 2022 10:43 AM
To: Kasemir, Kay <kasemirk at ornl.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Re: PVStructure vs Structure
Thank you Kay.
Sent: Friday, June 10, 2022 7:38 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Madden, Timothy J. <tmadden at anl.gov>
> In pvData, we have PVStructures which I guess define data structures, and Structures which have something to do with introspection.
> What exactly is the difference?
Good question.
In the original pvDataCPP/pvDataJava code, there was a distinction between describing what the data looks like, and a container that actually holds that data.
This has been a stumbling block for me as well because from just the naming in the API I couldn't tell what's what.
In most cases, you need the container:
A server needs to hold the data that it wants to serve.
A client needs to hold the data that it received.
The only case where just need the type info is for the "pvinfo" command.
On the protocol level, a client also receives just the type info when it first connects to a PV, but within a millisecond it then needs to create the container to hold the data.
In the second wave of implementing the protocol, we contemplated just having the container classes. For the "pvinfo" case you would then get a container that happens to be empty. OK, a few wasted "zero" bytes, but cuts the source code and API roughly in half!
With the new Java implementation, that's actually the case, there are only "containers", so a server looks like https://github.com/ControlSystemStudio/phoebus/blob/master/core/pva/src/test/java/org/epics/pva/server/ServerDemo.java
For the new C++ implementation, the API is also real simple, no step-1-build-description, step-2-build-container: https://github.com/mdavidsaver/pvxs/blob/master/example/simplesrv.cpp
I'm not sure to which extend the new C++ implementation might internally still have description-without-data, but as an end user you don't really see that.
-Kay
PVStructure vs Structure Madden, Timothy J. via Tech-talk
Re: PVStructure vs Structure Kasemir, Kay via Tech-talk
Re: PVStructure vs Structure Madden, Timothy J. via Tech-talk
Prev: Re: PVStructure vs Structure Madden, Timothy J. via Tech-talk
Next: Re: PVStructure vs Structure Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
