1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: PVStructure vs Structure
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Madden, Timothy J." <[email protected]>
Date: Fri, 10 Jun 2022 07:53:19 -0700
On 6/9/22 10:43, Madden, Timothy J. via Tech-talk wrote:
In pvData, we have PVStructures which I guess define data structures, and Structures which have something to do with introspection.
What exactly is the difference? In the docs, there is no real explanation of why we need both types, and what the difference is. Can one convert one to the other? Can someone explain this in a sentence or two?
In the PVXS library, the equivalents of Structure and PVStructure are named TypeDef and Value.
Does this help?
I have been writing pvData code that works, but only by following examples, and not really understanding the point of Structure vs PVStructure.
You are not alone.  I would advise starting with PVXS.  From the feedback I've had so far,
it is easier to pick up.
https://mdavidsaver.github.io/pvxs/example.html#shortest-server
https://mdavidsaver.github.io/pvxs/overview.html#comparison-with-pvaccesscpp
https://mdavidsaver.github.io/pvxs/value.html
PVStructure vs Structure Madden, Timothy J. via Tech-talk
Prev: Re: PVStructure vs Structure Kasemir, Kay via Tech-talk
Next: measComp R4-0 available Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: StreamDevice with a REST API Chris Gregory - STFC UKRI via Tech-talk
