1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: PINI field not working with modbus
To: "Marco A. Barra Montevechi Filho" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 27 Jul 2022 11:58:38 +0000
Hi Marco,
Our messages just crossed.  Please see if adding the epicsThreadSleep(1.0) fixes the problem.
If not, my previous instructions had a typo, I wanted you to type "dbpr LCI:X:NEGPowerMINI:TargetVoltRead 2", not dbpf.
From: Marco A. Barra Montevechi Filho <[email protected]>
Sent: Wednesday, July 27, 2022 6:53 AM
To: Mark Rivers <[email protected]>; [email protected] <[email protected]>
Hi Mark!
I did the recommended and append the results below. I also commented every modbus function that was not
NEG_EMODBUS_1_1_Rd_VTarget
 and every record that was not
${BL}:${H}:${EQ}:TargetVoltRead
so i could focus the debug on this. Using wireshark captures and filtering by the device I.P., i noticed something interesting (I append the capture files in this e-mail): even when TargetVoltRead SCAN is set to Passive, my computer keeps sending modbusTCP queries for the device and it even gets the answer. Should that be happening? It seems to me that the only difference between Passive and 1 Second scan is that passive doesnt store the queried info in the database while 1 second scan does, but both query the device.
About the recommended debug: my st.cmd file now looks like:
#!/home/marco/work/cnpem_git/LCI/NEGPowerMINI/bin/linux-x86_64/NEG
< /home/marco/work/cnpem_git/LCI/NEGPowerMINI/iocBoot/iocNEG/envPaths
epicsEnvSet("BL","LCI")
epicsEnvSet("H","X")
epicsEnvSet("EQ","NEGPowerMINI")
epicsEnvSet("IOCNAME","NEG")
# Configuração da linha de luz
< /home/marco/work/cnpem_git/LCI/NEGPowerMINI/iocBoot/iocNEG/NEG.config
epicsEnvSet("STREAM_PROTOCOL_PATH","${TOP}/db")
cd ${TOP}
dbLoadDatabase "dbd/NEG.dbd"
NEG_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("EMODBUS","10.20.41.90:502",0,0,1)
modbusInterposeConfig("EMODBUS",0,3000,0)
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_SoftwareVersion", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ}, 0x1000, 1,  2, ${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_HardwareVersion", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x1002,1,2,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_PowerSuppIntState", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2000,1,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_LoggingState", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2001,1,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_SysUptime", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2002,2,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_InternalTemperature", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2004,1,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_PumpTemperature", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2005,1,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_OutVolt", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2006,1,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_OutCurr", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2007,1,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_TimeRunning", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2008,2,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_Alarms", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200A,2,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_TempAlarms", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200C,2,0,${MBUS_POLL}, "");
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_WorkTime", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200E,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_VTarget", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x3000,1,0,${MBUS_POLL}, "");
asynSetTraceMask NEG_EMODBUS_1_1_Rd_VTarget -1 9
dbLoadRecords("db/dbNEG.db", "BL=${BL}, H=${H}, EQ=${EQ}")
cd ${TOP}/iocBoot/${IOC}
iocInit
the resumed output, along with the typed dbpf is below. Interestingly, after the dbpf, cagetting into te record retrieved its right value: 12, and not 0.
## Start any sequence programs
#seq sncxxx,"user=gabrielfedelHost"
epics> 2022/07/27 11:48:18.848 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/27 11:48:19.879 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/27 11:48:20.905 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/27 11:48:21.932 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
dbpf LCI:X:NEGPowerMINI:TargetVoltRead 2
DBR_DOUBLE:         2
epics> 2022/07/27 11:48:22.528 drvModbusAsyn::readInt32 port NEG_EMODBUS_1_1_Rd_VTarget function=0x3, offset=00, value=0x4b0
2022/07/27 11:48:22.963 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/27 11:48:23.994 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/27 11:48:25.025 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
I dont think there is any new info in the following but if needed: the complete ioc init log output is:
epicsEnvSet("IOC","iocNEG")
epicsEnvSet("TOP","/home/marco/work/cnpem_git/LCI/NEGPowerMINI")
epicsEnvSet("NFS","/usr/local/epics-nfs")
epicsEnvSet("SUPPORT","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support")
epicsEnvSet("ASYN","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/asyn-R4-33")
epicsEnvSet("STREAM","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/stream-R2-7-7c")
epicsEnvSet("MODBUS","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/modbus-R2-11")
epicsEnvSet("AUTOSAVE","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/autosave-R5-9")
epicsEnvSet("EPICS_BASE","/usr/local/epics-nfs/base/R3.15.6")
epicsEnvSet("ALIVE","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/alive-R1-1-0")
epicsEnvSet("BUSY","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/busy-R1-7")
epicsEnvSet("CALC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/calc-R3-7-1")
epicsEnvSet("CAMAC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/camac-R2-7-1")
epicsEnvSet("CAPUTRECORDER","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/caputRecorder-R1-7-1")
epicsEnvSet("DAC128V","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/dac128V-R2-9")
epicsEnvSet("DELAYGEN","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/delaygen-R1-2-0")
epicsEnvSet("DXP","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/dxp-R5-0")
epicsEnvSet("DXPSITORO","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/dxpSITORO-R1-1")
epicsEnvSet("DEVIOCSTATS","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/iocStats-3-1-15")
epicsEnvSet("IP","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/ip-R2-19-1")
epicsEnvSet("IPAC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/ipac-2-15")
epicsEnvSet("IP330","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/ip330-R2-9")
epicsEnvSet("IPUNIDIG","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/ipUnidig-R2-11")
epicsEnvSet("LOVE","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/love-R3-2-6")
epicsEnvSet("LUA","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/lua-R1-2-2")
epicsEnvSet("MCA","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/mca-R7-7")
epicsEnvSet("MEASCOMP","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/measComp-R2-1")
epicsEnvSet("MODBUS_2_10_1","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/modbus-R2-10-1")
epicsEnvSet("MOTOR","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/motor-R6-10-1")
epicsEnvSet("OPTICS","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/optics-R2-13-1")
epicsEnvSet("QUADEM","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/quadEM-R9-1")
epicsEnvSet("SOFTGLUE","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/softGlue-R2-8-1")
epicsEnvSet("SOFTGLUEZYNQ","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/softGlueZynq-R2-0-1")
epicsEnvSet("SSCAN","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/sscan-R2-11-1")
epicsEnvSet("STD","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/std-R3-5")
epicsEnvSet("VAC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/vac-R1-7")
epicsEnvSet("VME","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/vme-R2-9")
epicsEnvSet("YOKOGAWA_DAS","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/Yokogawa_DAS-R1-0-0")
epicsEnvSet("XXX","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/xxx-R6-0")
epicsEnvSet("AREA_DETECTOR","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/areaDetector-R3-3-1")
epicsEnvSet("ADCORE","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/areaDetector-R3-3-1/ADCore")
epicsEnvSet("ADSUPPORT","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/areaDetector-R3-3-1/ADSupport")
epicsEnvSet("ADSIMDETECTOR","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/areaDetector-R3-3-1/ADSimDetector")
epicsEnvSet("SNCSEQ","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/seq-2-2-5")
epicsEnvSet("ALLEN_BRADLEY","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.0/support/allenBradley-2-3")
epicsEnvSet("E_SHM","eurotherm")
epicsEnvSet("MBUS_SL_ADDR",1)
epicsEnvSet("MBUS_READ",3)
epicsEnvSet("MBUS_WRITE",6)
epicsEnvSet("MBUS_POLL",1000)
epicsEnvSet("STREAM_PROTOCOL_PATH","/home/marco/work/cnpem_git/LCI/NEGPowerMINI/db")
cd /home/marco/work/cnpem_git/LCI/NEGPowerMINI
#######NOT USED ANYMORE. KEEPING FOR HISTORICAL REASONS###
## Configured by http://cars9.uchicago.edu/software/epics/modbusDoc.html
## Parameters to ModBus on /dev/ttyUSB0
## used to USB
#drvAsynSerialPortConfigure("EMODBUS","10.20.41.90:4001",0,0,0)
########NOT USED ANYMORE. KEEPING FOR HISTORICAL REASONS###
# Set up ASYN HYPPIE ports
# pxiCreateSM(asyn, shared memory name)
# drvasynPXIConfig(port, COM port, shared memory name, serial type)
#asynSetOption("EMODBUS", 0, "${BAUD}", "9600")
#asynSetOption("EMODBUS", 0, "bits", "8")
#asynSetOption("EMODBUS", 0, "parity", "none")
#asynSetOption("EMODBUS", 0, "stop", "1")
## Configure
# drvModbusAsynConfigure(portName,      => create a name
#                       tcpPortName,    => defined before
#                       slaveAddress,   => defined on equipament
#                       modbusFunction, => 3 : Read Holding Register (16-bit)
#                       modbusStartAddress, => adress of register
#                       modbusLength,  => the length of data segment
#                       dataType,  => default data type
#                       pollMsec,
#                       plcType);     => Equipament name, not used
# drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_SoftwareVersion", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ}, 0x1000, 1,2, ${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_VTarget", "EMODBUS", 1,3,0x3000,1,0,1000, "");
#drvModbusAsynConfigure("NEG_EMODBUS_1_1_Wr_VTarget", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_WRITE},0x3000,1,0,${MBUS_POLL}, "");
## Load record instances
dbLoadRecords("db/dbNEG.db", "BL=LCI, H=X, EQ=NEGPowerMINI")
cd /home/marco/work/cnpem_git/LCI/NEGPowerMINI/iocBoot/iocNEG
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Sep 27 2021
2022/07/27 11:48:18.322 drvModbusAsyn::readInt32 port NEG_EMODBUS_1_1_Rd_VTarget function=0x3, offset=00, value=0x0
DBR_DOUBLE:         2
As always, thanks for the help.
Marco
Sent: 26 July 2022 20:37
To: Marco A. Barra Montevechi Filho <[email protected]>; [email protected] <[email protected]>
Subject: RE: PINI field not working with modbus
Hi Marco,
Please start the IOC with TargetVoltRead.SCAN=Passive and .PINI=YES.  Set the asynTraceMask for the NEG_EMODBUS_1_1_Rd_VTarget driver to 9, but do that immediately after you create the driver, not at the end of the startup script.  Then when the startup is complete type the following command and send the output.  Also send the output of all driver trace messages that occur before you type dbpf.
dbpf TargetVoltRead 2
Of course you need to add all of the prefixes for TargetVoltRead.
Sent: Tuesday, July 26, 2022 9:10 AM
Of course!
it is defined in the st.cmd as:
I append the full st.cmd file below. I also tried to define other functions PINI to YES and FNLK to
"${BL}:${H}:${EQ}:TargetVoltRead", but to no avail.
Any suggestions on how to improve the st.cmd are also welcome.
cd ${TOP}
## Configure
#                       pollMsec,
iocInit
Thanks for the help
Marco
Sent: 26 July 2022 10:33
To: [email protected] <[email protected]>; Marco A. Barra Montevechi Filho <[email protected]>
Hi Marco,
Can you show us how the NEG_EMODBUS_1_1_Rd_VTarget port is configured?
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Tuesday, July 26, 2022 7:45 AM
Subject: PINI field not working with modbus
Hello all.
I have an analog in record for reading a modbus register from a device. The record is defined as follows:
record(ai, "${BL}:${H}:${EQ}:TargetVoltRead"){
    field(DESC, "Voltage set on target [V].")
    field(DTYP, "asynInt32")
    field(EGU, "V")
    field(ASLO, 0.01)
    field(INP, "@asyn(NEG_EMODBUS_1_1_Rd_VTarget,0,1000)MODBUS_DATA")
    field(SCAN, "1 second")
Which reads fine. However, if i set the PINI field to YES and the scan to passive:
    field(EGU, "V")
    field(ASLO, 0.01)
    field(SCAN, "Passive")
    field(PINI, "YES")
i get only 0 as value when cagetting the PV. Am i doing something wrong?
Thanks in advance.
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Re: PINI field not working with modbus Mark Rivers via Tech-talk
Re: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
RE: PINI field not working with modbus Mark Rivers via Tech-talk
Prev: Re: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: PINI field not working with modbus Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
