1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: PINI field not working with modbus
From: bob dalesio via Tech-talk <[email protected]>
Cc: "Marco A. Barra Montevechi Filho" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 27 Jul 2022 08:09:52 -0400
The status and severity should have also reflected that the value was invalid.
It is a good practice to always consider those fields in any application. Otherwise, a loss of communication from the IOC to the device will not be detected.
On Wed, Jul 27, 2022 at 7:52 AM Mark Rivers via Tech-talk <[email protected]> wrote:
Hi Marco,
I think I understand why you are not seeing the correct value when you use PINI=YES and SCAN=Passive.  The problem is a race condition.
As I said in a previous message, it appears that you have set the MBUS_POLL macro to 1000, which means the poller for that Modbus driver is running every 1000 ms (1 second).  The poller waits for this delay at the beginning of the poll loop.  The poller thread is started when your startup script calls drvModbusAsynConfigure().  When the record processes during iocInit() because PINI=YES it just gets the most recent value from the poller.
However, in your case because you have a slow polling rate of 1 second it is likely that the poller has not yet done the first poll when the record is processed during iocInit, so there is no value to use.
I believe you can fix the problem by adding this line to your startup script just before iocInit()
epicsThreadSleep(1.0)
Sent: Tuesday, July 26, 2022 6:37 PM
To: Marco A. Barra Montevechi Filho <[email protected]>; [email protected] <[email protected]>
Subject: RE: PINI field not working with modbus
Hi Marco,
Please start the IOC with TargetVoltRead.SCAN=Passive and .PINI=YES.  Set the asynTraceMask for the NEG_EMODBUS_1_1_Rd_VTarget driver to 9, but do that immediately after you create the driver, not at the end of the startup script.  Then when the startup is complete type the following command and send the output.  Also send the output of all driver trace messages that occur before you type dbpf.
dbpf TargetVoltRead 2
Of course you need to add all of the prefixes for TargetVoltRead.
From: Marco A. Barra Montevechi Filho <[email protected]>
Sent: Tuesday, July 26, 2022 9:10 AM
To: Mark Rivers <[email protected]>; [email protected]
Of course!
it is defined in the st.cmd as:
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_VTarget", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x3000,1,0,${MBUS_POLL}, "");
I append the full st.cmd file below. I also tried to define other functions PINI to YES and FNLK to
"${BL}:${H}:${EQ}:TargetVoltRead", but to no avail.
Any suggestions on how to improve the st.cmd are also welcome.
#!/home/marco/work/cnpem_git/LCI/NEGPowerMINI/bin/linux-x86_64/NEG
< /home/marco/work/cnpem_git/LCI/NEGPowerMINI/iocBoot/iocNEG/envPaths
epicsEnvSet("BL","LCI")
epicsEnvSet("H","X")
epicsEnvSet("EQ","NEGPowerMINI")
epicsEnvSet("IOCNAME","NEG")
# Configuração da linha de luz
< /home/marco/work/cnpem_git/LCI/NEGPowerMINI/iocBoot/iocNEG/NEG.config
epicsEnvSet("STREAM_PROTOCOL_PATH","${TOP}/db")
cd ${TOP}
dbLoadDatabase "dbd/NEG.dbd"
NEG_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("EMODBUS","10.20.41.90:502",0,0,1)
########NOT USED ANYMORE. KEEPING FOR HISTORICAL REASONS###
# Set up ASYN HYPPIE ports
# pxiCreateSM(asyn, shared memory name)
# drvasynPXIConfig(port, COM port, shared memory name, serial type)
#asynSetOption("EMODBUS", 0, "${BAUD}", "9600")
#asynSetOption("EMODBUS", 0, "bits", "8")
#asynSetOption("EMODBUS", 0, "parity", "none")
#asynSetOption("EMODBUS", 0, "stop", "1")
## Configure
modbusInterposeConfig("EMODBUS",0,3000,0)
# drvModbusAsynConfigure(portName,      => create a name
#                       tcpPortName,    => defined before
#                       slaveAddress,   => defined on equipament
#                       modbusFunction, => 3 : Read Holding Register (16-bit)
#                       modbusStartAddress, => adress of register
#                       modbusLength,  => the length of data segment
#                       dataType,  => default data type
#                       pollMsec,
#                       plcType);     => Equipament name, not used
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_SoftwareVersion", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ}, 0x1000, 1,    2, ${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_HardwareVersion", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x1002,1,2,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_PowerSuppIntState", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2000,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_LoggingState", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2001,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_SysUptime", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2002,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_InternalTemperature", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2004,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_PumpTemperature", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2005,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_OutVolt", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2006,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_OutCurr", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2007,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_TimeRunning", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2008,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_Alarms", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200A,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_TempAlarms", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200C,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_WorkTime", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200E,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Wr_VTarget", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_WRITE},0x3000,1,0,${MBUS_POLL}, "");
## Load record instances
dbLoadRecords("db/dbNEG.db", "BL=${BL}, H=${H}, EQ=${EQ}")
cd ${TOP}/iocBoot/${IOC}
iocInit
Thanks for the help
Marco
Sent: 26 July 2022 10:33
To: [email protected] <[email protected]>; Marco A. Barra Montevechi Filho <[email protected]>
Hi Marco,
Can you show us how the NEG_EMODBUS_1_1_Rd_VTarget port is configured?
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Tuesday, July 26, 2022 7:45 AM
Subject: PINI field not working with modbus
Hello all.
I have an analog in record for reading a modbus register from a device. The record is defined as follows:
record(ai, "${BL}:${H}:${EQ}:TargetVoltRead"){
    field(DESC, "Voltage set on target [V].")
    field(DTYP, "asynInt32")
    field(EGU, "V")
    field(ASLO, 0.01)
    field(INP, "@asyn(NEG_EMODBUS_1_1_Rd_VTarget,0,1000)MODBUS_DATA")
    field(SCAN, "1 second")
Which reads fine. However, if i set the PINI field to YES and the scan to passive:
    field(EGU, "V")
    field(ASLO, 0.01)
    field(SCAN, "Passive")
    field(PINI, "YES")
i get only 0 as value when cagetting the PV. Am i doing something wrong?
Thanks in advance.
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: PINI field not working with modbus Mark Rivers via Tech-talk
PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Re: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
RE: PINI field not working with modbus Mark Rivers via Tech-talk
Prev: Re: PINI field not working with modbus Mark Rivers via Tech-talk
Next: Re: PINI field not working with modbus Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
