1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Epics archiver appliance freezing
From: "Shankar, Murali via Tech-talk" <tech-talk at aps.anl.gov>
To: "Manoussakis, Adamandios" <manoussakis1 at llnl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 1 Sep 2022 18:20:51 +0000
Do you have unreachable appliances in your appliances.xml? That might explain the "The web application [mgmt] is still processing a request that has yet to finish." and your other issues. The call at org.epics.archiverappliance.mgmt.bpl.GetPVStatusAction.execute(GetPVStatusAction.java:90) is a call to the engine to get the status of the PV and for some reason this is not completing and gets stuck. And eventually you run out of HTTP threads and the UI freezes.
Murali
From: Manoussakis, Adamandios <manoussakis1 at llnl.gov>
Sent: Thursday, September 1, 2022 10:10 AM
To: Shankar, Murali <mshankar at slac.stanford.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: Epics archiver appliance freezing
Hi Murali,
So far been looking through mgmt logs again but todays logs 9-1-2022 after a crash did not show this null pointer exception below.
from localhost.2022-08-31.log looks like this may be the culprit for crashing but I am not sure where to find or get rid of this issue.  I have looked at other setups I have of the AA and nothing similar has popped up in the logs.  The interesting part is a reboot will seem to get the AA back to normal and you can use it up until I run our CSS and cause PVs to change -> causing the AA to start archiving.  After say 25 runs then the AA freezes.
31-Aug-2022 19:02:35.663 SEVERE [http-nio-17665-exec-1] org.apache.catalina.core.StandardHostValve.invoke Exception Processing null
java.lang.NullPointerException
                at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:242)
                at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
                at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:490)
                at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
                at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
                at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:668)
                at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
                at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
                at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:408)
                at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
                at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:834)
                at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1415)
                at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
                at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
                at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
                at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
                at java.base/java.lang.Thread.run(Thread.java:829)
from catalina.2022-08-31.log I am guessing this is due to this null pointer issue, is it possibly a bad PV name or a bug in the web viewer/archiver that is allowing some malformed PV name to get stored.
01-Sep-2022 09:12:41.526 WARNING [Thread-5] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [mgmt] is still processing a request that has yet to finish. This is very likely to create a memory leak. You can control the time allowed for requests to finish by using the unloadDelay attribute of the standard Context implementation. Stack trace of request processing thread:[
[email protected]/java.net.SocketInputStream.socketRead0(Native Method)
[email protected]/java.net.SocketInputStream.socketRead(SocketInputStream.java:115)
[email protected]/java.net.SocketInputStream.read(SocketInputStream.java:168)
[email protected]/java.net.SocketInputStream.read(SocketInputStream.java:140)
org.apache.http.impl.io.SessionInputBufferImpl.streamRead(SessionInputBufferImpl.java:136)
org.apache.http.impl.io.SessionInputBufferImpl.fillBuffer(SessionInputBufferImpl.java:152)
org.apache.http.impl.io.SessionInputBufferImpl.readLine(SessionInputBufferImpl.java:270)
org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:140)
org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:57)
org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:260)
org.apache.http.impl.DefaultBHttpClientConnection.receiveResponseHeader(DefaultBHttpClientConnection.java:161)
org.apache.http.impl.conn.CPoolProxy.receiveResponseHeader(CPoolProxy.java:153)
org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:271)
org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:123)
org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:254)
org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:195)
org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:86)
org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:108)
org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:106)
org.epics.archiverappliance.utils.ui.GetUrlContent.postStringListAndGetJSON(GetUrlContent.java:350)
org.epics.archiverappliance.common.BasicDispatcher.dispatch(BasicDispatcher.java:99)
org.epics.archiverappliance.mgmt.BPLServlet.doGet(BPLServlet.java:198)
javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:200)
[email protected]/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
[email protected]/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
[email protected]/java.lang.Thread.run(Thread.java:829)]
from localhost_access_log.2022-08-31.txt, I assume the 1 second intervals for this request is some sort of polling to grab them? And the other endpoint seems to poll on a 5 min interval.
27.0.0.1 - - [31/Aug/2022:19:39:53 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:02 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:03 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:04 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:08 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:09 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:10 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:11 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:12 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:13 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:14 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:15 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:16 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:17 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:18 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:19 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:20 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
127.0.0.1 - - [31/Aug/2022:19:40:23 -0700] "GET /mgmt/bpl/getPVStatus?pv=PV1%3AST%3AID%3A*&reporttype=short HTTP/1.1" 200 1202
IP ADDR - - [01/Sep/2022:00:04:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:09:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:14:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:19:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:24:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:29:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:34:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:39:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:44:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:49:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:54:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:00:59:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:04:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:09:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:14:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:19:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:24:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:29:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:34:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:39:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:44:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:49:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:54:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:01:59:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:04:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:09:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:14:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:19:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:24:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:29:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:34:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:39:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:44:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:49:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:54:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:02:59:03 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:04:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:09:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:14:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:19:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:24:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:29:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:34:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:39:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:44:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:49:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:54:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:03:59:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:04:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:09:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:14:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:19:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:24:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:29:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:34:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:39:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:44:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:49:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:54:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:04:59:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:04:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:09:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:14:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:19:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:24:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:29:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:34:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:39:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:44:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:49:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:54:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:05:59:04 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:04:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:09:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:14:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:19:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:24:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:29:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:34:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:39:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:44:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:49:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:54:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:06:59:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:04:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:09:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:14:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:19:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:24:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:29:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:34:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:39:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:44:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:49:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:54:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:07:59:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:04:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:09:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:14:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:19:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:24:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:29:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:34:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:39:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:44:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:49:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:54:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:08:59:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:09:04:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
IP ADDR - - [01/Sep/2022:09:09:05 -0700] "GET /mgmt/bpl/getPVsForThisAppliance HTTP/1.1" 200 183961
I am getting close to just reinstall the AA, but wanted to check if there is a way to clear out the list of PVs the AA SQL database has?  The Website doesn’t seem to have an option to mass delete PVs, although not sure this would solve the issue.
Adam
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Shankar, Murali via Tech-talk
Sent: Thursday, September 1, 2022 7:11 AM
To: tech-talk at aps.anl.gov
>> Is there a specific log to look into to see the freeze up, most of the logs I’ve checked out have tons of information but not sure what I am searching for as the culprit
I would first look in the mgmt's ( and subsequently the other component's) localhost logs to determine which request is causing the issue. Once you narrow down the request; you can look in the code/try adding additional log statements etc. Check for anything related to out of memory etc. Does restarting fix this issue temporarily? Also, did you check the browser's console log for any client side exception?
>> but it just will not return anything status wise about the PV search.
I think most of this is done in memory on the mgmt instance. However; the cluster needs to be active and alive for this to work correctly. So any info on actions that takes the cluster down ( out of memory, for example) would help.
Murali
RE: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
Re: Epics archiver appliance freezing Shankar, Murali via Tech-talk
Prev: RE: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
Next: RE: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
