1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: PVXS and Phoebus
From: Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 5 Oct 2022 16:40:20 +0200
Hey all,
I have written a small program using the PVXS library. Trying to access the PVs with Phoebus release 4.7.0 I encountered an issues:
I'm using a boolean button widget in Phoebus to access a NTScalar with boolean type and get the message "Cannot decode ..."
In the shell I get the message:
2022-10-05 16:24:10 WARNING [org.phoebus.pv] Cannot decode 'PND:LMD:RUNCTRL:SHUTDOWN' [CID 2, SID 117768961 CONNECTED] = epics:nt/NTScalar:1.0
    boolean value false
    alarm_t alarm [NO_ALARM]
        int severity 0
        int status 0
        string message
    time_t timeStamp [2022-10-05 16:23:26.000318114]
        long secondsPastEpoch 1664979806
        int nanoseconds 318114
        int userTag 0
java.lang.Exception: Expected struct with scalar 'value', got epics:nt/NTScalar:1.0
    boolean value false
        int severity 0
        int status 0
        string message
        int userTag 0
    at org.phoebus.pv.pva.PVAStructureHelper.decodeScalar(PVAStructureHelper.java:148)     at org.phoebus.pv.pva.PVAStructureHelper.getVType(PVAStructureHelper.java:99)
    at org.phoebus.pv.pva.PVA_PV.handleMonitor(PVA_PV.java:88)
    at org.epics.pva.client.MonitorRequest.decodeValueUpdate(MonitorRequest.java:236)     at org.epics.pva.client.MonitorRequest.handleResponse(MonitorRequest.java:198)     at org.epics.pva.client.MonitorHandler.handleCommand(MonitorHandler.java:40)     at org.epics.pva.client.MonitorHandler.handleCommand(MonitorHandler.java:21)     at org.epics.pva.common.CommandHandlers.handleCommand(CommandHandlers.java:66)     at org.epics.pva.client.ClientTCPHandler.handleApplicationMessage(ClientTCPHandler.java:331)
    at org.epics.pva.common.TCPHandler.handleMessage(TCPHandler.java:394)
    at org.epics.pva.common.TCPHandler.receiver(TCPHandler.java:294)
    at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
    at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)     at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
    at java.base/java.lang.Thread.run(Thread.java:833)
Is the boolean type not implemented in Phoebus? In that case I would switch to an int value.
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: [EXTERNAL] PVXS and Phoebus Kasemir, Kay via Tech-talk
Prev: Re: Read and Write errors with VME-EVR-300 Jukka Pietarinen via Tech-talk
Next: Re: Read and Write errors with VME-EVR-300 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: How to read ENUM type PV using PvaClientChannel calss? Jörn Dreyer via Tech-talk
Next: Re: [EXTERNAL] PVXS and Phoebus Kasemir, Kay via Tech-talk
ANJ, 10 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
