1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: asynMotorController weird behavior when using any read/write interface mask
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 6 Oct 2022 10:08:01 +0000
Hello Mark
I called the base class functions and it worked. I have two questions:
1.       In this case do I need to call the controller or axis classes callbacks?
2.       For the SPMG field, when going from Go to Move the GUI gives me “Controller Error” and the RBV field does not update until it reaches its destination, this is very similar to the original behavior. This also happened when I reverted my updates for read/write Int32 interfaces.
Thanks!
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Thursday, September 29, 2022 4:04 PM
To: Mark Rivers <[email protected]>; [email protected]
Thanks Mark. I will test it and get back to you. Out of curiosity why did this happen? why do I have to call the base class functions?
Best Regards
Abdalla.
Sent: Thursday, September 29, 2022 3:52 PM
To: [email protected]; Abdalla Ahmad <[email protected]>
Subject: Re: asynMotorController weird behavior when using any read/write interface mask
Hi Abdalla,
I suspect the problem is that in your writeInt32 and readInt32 methods you have forgotten that you must call the base class method (asynMotorController::writeInt32 or readInt32) for any parameters that are not specific to your derived class.  That would cause SPMG and STOP not to work.
Here is an example of how to do it:
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Thursday, September 29, 2022 1:51 AM
To:
[email protected] <[email protected]>
Subject: asynMotorController weird behavior when using any read/write interface mask
Hi
Recently we got the chance to control the SMC Taurus rotary stage using the motorMicos motor record module. One of my updates was to read and write limit switches status. The command’s argument is an integer value (0-2), I implemented readIn32 and writeInt32 interfaces as usual. When moving the motor, after a while the RBV field does not update, STOP and SPMG fields do not work (The motor doesn’t stop), and it the GUI gives me “Controller Error”. When the motor reaches its destination, the controller error clears and the RBV field is updated accordingly. I tried empty readInt32 and writeInt32 functions with only “return asynSuccess” and the behavior is still there. When I removed those interfaces, the controller works fine. To make those commands work I moved the writeReadController and writeController functions to the poll thread and the motor works fine, motor stops at command and the RBV field is updated. Any clue on what I have missed?
Thanks!
Abdalla.
RE: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
Re: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
RE: asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
Prev: Re: EPICS Base 3.14.12.8 build error on CentOS 9 Maren Purves via Tech-talk
Next: Re: EPICS Base 3.14.12.8 build error on CentOS 9 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
Next: RE: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
