1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: asynMotorController weird behavior when using any read/write interface mask
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 29 Sep 2022 13:17:37 +0000
> Out of curiosity why did this happen? why do I have to call the base class functions?
The base class asynMotorController::writeInt32() is what handles the STOP and SPMG fields, as well as many other fields.  If you don't call that method then changes to those fields will be ignored.  When you implement a virtual method in your derived class then your derived class method is called, rather than the base class method.  But in drivers like this you need to call the base class method if the parameter you were passed is not one that your derived class handles.
From: Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo>
Sent: Thursday, September 29, 2022 8:03 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: asynMotorController weird behavior when using any read/write interface mask
Thanks Mark. I will test it and get back to you. Out of curiosity why did this happen? why do I have to call the base class functions?
Best Regards
Abdalla.
Sent: Thursday, September 29, 2022 3:52 PM
To: tech-talk at aps.anl.gov; Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo>
Hi Abdalla,
I suspect the problem is that in your writeInt32 and readInt32 methods you have forgotten that you must call the base class method (asynMotorController::writeInt32 or readInt32) for any parameters that are not specific to your derived class.  That would cause SPMG and STOP not to work.
Here is an example of how to do it:
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, September 29, 2022 1:51 AM
To:
Subject: asynMotorController weird behavior when using any read/write interface mask
Hi
Recently we got the chance to control the SMC Taurus rotary stage using the motorMicos motor record module. One of my updates was to read and write limit switches status. The command’s argument is an integer value (0-2), I implemented readIn32 and writeInt32 interfaces as usual. When moving the motor, after a while the RBV field does not update, STOP and SPMG fields do not work (The motor doesn’t stop), and it the GUI gives me “Controller Error”. When the motor reaches its destination, the controller error clears and the RBV field is updated accordingly. I tried empty readInt32 and writeInt32 functions with only “return asynSuccess” and the behavior is still there. When I removed those interfaces, the controller works fine. To make those commands work I moved the writeReadController and writeController functions to the poll thread and the motor works fine, motor stops at command and the RBV field is updated. Any clue on what I have missed?
Thanks!
Abdalla.
asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
Re: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
RE: asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
Prev: RE: asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
Next: Re: DMOV flag problem with soft motor Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: RE: asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
ANJ, 06 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
