1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: add motor module in synapps
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: 网易邮件中心 <l123173 at 163.com>, tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 18 Oct 2022 14:25:40 -0500
Liang,
Where there any errors on the IOC's shell after the dbLoadTemplate call that loads motor.substitutions from the motorSim example IOC?
It's probably a better idea to load the motorSim.iocsh file, which can be uncommented from motors.iocsh in xxx:
https://github.com/epics-modules/xxx/blob/e798cbdecc3d394436dd2f9b504d27f59f6b6d32/iocBoot/iocxxx/examples/motors.iocsh#L6
Kevin
On 10/17/22 04:30, 网易邮件中心 via Tech-talk wrote:
Hi all,
     I am using synapps_6_1 and xxx module.
    Now I started the xxx ioc, sscan module was good, but motor was not.  And  I want to use the simulate Motor.     Then I modified "common.iocsh" in xxx-R6-1/iocBoot/iocxxx, added following lines:
/iocshLoad("$(MOTOR)/iocsh/allstop.iocsh", "P=$(PREFIX)")/
/dbLoadTemplate("$(MOTOR)/modules/motorMotorSim/iocs/motorSimIOC/iocBoot/iocMotorSim/motor.substitutions")/
      It failed except the "AllStop Button" in xxx OPI.
      How should i do it, add the simMotor in xxx.
Liang
add motor module in synapps 网易邮件中心 via Tech-talk
Prev: Db/Makefile infinite loop Pearson, Matthew via Tech-talk
Next: RE: Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: add motor module in synapps 网易邮件中心 via Tech-talk
Next: Current open Controls positions at ITER Ralph Lange via Tech-talk
ANJ, 18 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
