1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Attocube AMC100
From: "Ivashkevych, Oksana via Tech-talk" <tech-talk at aps.anl.gov>
To: "Lang, Keenan C." <klang at anl.gov>, Tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 18 Oct 2022 20:27:45 +0000
Hi Keenan,
Thank you very much.
After changing the lua scrip file the way you suggested, I was able to move all my three motors.
After running a few tests, I have discovered a few other problems:
The motor does not stop on the limit.  It does show that the limit has been hit, but it continues to output current pushing the motor forward.  Writing 1 to the STOP does not help, and later I have tested that the STOP does not work at all for me.
The ways I was able to stop are 1) shut power to the controller, 2) disconnect controller from the beamline,  connect to the laptop, run vendor app and press the stop there.
I was wondering if anyone else in APS or other places experienced similar problems and what did you do about it?
Also would appreciate suggestion how I could fix it.
Thank you
Oksana
Sent: Monday, October 17, 2022 5:55 PM
To: Ivashkevych, Oksana <oksana at bnl.gov>; Tech-talk <tech-talk at aps.anl.gov>
Subject: Re: Attocube AMC100
I didn't experience this with the device I originally tested on, but I do know that Dave Cyl here at the APS did end up running into a similar issue with a more recent AMC100. We think that there were API changes causing behavior changes, but haven't been able to fully test out changes.
What he ended up changing:
Add the following to the move function, after the send(request) line that sends a request for "com.attocube.amc.move.setControlTargetPosition"
local request = {
                        jsonrpc = "2.0",
                        method = "com.attocube.amc.control.setControlMove",
                        params = { AXIS ,true },
                        id = AXIS,
                        api = 2 }
send(request)
Add the following to the poll function, after it checks if limits have been reached:
if (status == "in target range") then
               local request = {
                        jsonrpc = "2.0",
                        params = { AXIS ,false },
                        id = AXIS,
                        api = 2 }
        send(request)
end
Keenan
Sent: Monday, October 17, 2022 2:31 PM
To: Lang, Keenan C. <klang at anl.gov>; Tech-talk <tech-talk at aps.anl.gov>
Hi Keenan at al,
It looks like I can not move the motors from the EPICS interface.  The  commanded position changes, but the readback does not.  No errors in the epics shell.
It seems the driver tries to moves it judging by Mtr.MOVN changing value, but the motor does not move.
If I exit the epics while motor is commanded to move and still makes attempts, I see these  errors:
2022/10/17 15:29:07.609 asynMotorController:writeFloat64 error, status=3 axis=0, function=1, value=1468813.000000
2022/10/17 15:29:07.609 devMotorAsyn::asynCallback: XF:18IDB-ES{Comp-m1}Mtr pasyn{Float64,Int32}->write returned
I have motors with sensors, I can move them from the vendor application.
Left only single motor configured  for now. Any ideas what could be wrong, or how I can troubleshoot it?
Thank you
iocScriptMotor]$ more motor.substitutions.Attocube_AMC
file "$(MOTOR)/db/asyn_motor.db"
  pattern
  {P,                M,  DTYP,        PORT,     ADDR,  DESC,    EGU,      DIR,  VMAX,  VELO,  VBAS,  ACCL,  BDST,     BVEL,  BACC,     MRES,      PREC,  DHLM,       DLLM,   INIT}
  {XF:18IDB-ES,     "{Comp-m1}Mtr", "asynMotor", AMC-1,   0,    "CLp Motor1",    mm,       Pos,  15.,   3.,    .05,    .5,    0,       1.0,    2, .025,    5,   0,       0,  ""}
##  {XF:18IDB-ES,     "{Comp-m2}Mtr", "asynMotor", AMC-1,   1,    "CLp Motor2",    mm,       Pos,  15.,   3.,    .05,    .5,    0,       1.0,    2, .025,    5,   0,       0,  ""}
##  {XF:18IDB-ES,     "{Comp-m3}Mtr", "asynMotor", AMC-1,   2,    "CLp Motor3",    mm,       Pos,  15.,   3.,    .05,    .5,    0,       1.0,    2, .025,    5,   0,       0,  ""}
file "$(TOP)/db/ScriptMotorReload.db"
  pattern
  {P,               PORT}
  {XF:18IDB-ES:,    AMC-1}
(base) [oksana@xf18idb-ioc1 iocScriptMotor]$ ./st.cmd.Attocube_AMC
#!../../bin/linux-x86_64/scriptMotor
< envPaths
epicsEnvSet("IOC","iocScriptMotor")
epicsEnvSet("TOP","/epics/devel/support/motor/modules/motorScriptMotor/iocs/scriptMotorIOC")
epicsEnvSet("MOTOR","/epics/devel/support/motor")
epicsEnvSet("ASYN","/epics/devel/support/asyn")
epicsEnvSet("SNCSEQ","/epics/devel/support/seq")
epicsEnvSet("BUSY","/epics/devel/support/busy")
epicsEnvSet("IPAC","/epics/devel/support/ipac")
epicsEnvSet("EPICS_BASE","/epics/devel/epics-base")
epicsEnvSet("SUPPORT","/epics/devel/support")
epicsEnvSet("LUA","/epics/devel/support/lua")
< /epics/common/xf18idb-ioc1-netsetup.cmd
# BEGIN ANSIBLE MANAGED BLOCK
epicsEnvSet("EPICS_CA_AUTO_ADDR_LIST",         "NO")
epicsEnvSet("EPICS_CA_ADDR_LIST",              "10.66.139.255")
epicsEnvSet("EPICS_CAS_AUTO_BEACON_ADDR_LIST", "NO")
epicsEnvSet("EPICS_CAS_BEACON_ADDR_LIST",      "10.66.139.255")
epicsEnvSet("EPICS_CAS_INTF_ADDR_LIST",        "10.66.139.26")
# END ANSIBLE MANAGED BLOCK
dbLoadDatabase("/epics/devel/support/motor/modules/motorScriptMotor/iocs/scriptMotorIOC/dbd/scriptMotor.dbd")
scriptMotor_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("LUA_SCRIPT_PATH", "./scripts")
#epicsEnvSet("IP_ADDRESS", "123.456.789.000")
epicsEnvSet("IP_ADDRESS", "10.66.138.124")
# Connect to virtual motor controller server
drvAsynIPPortConfigure("AMC","10.66.138.124:9090", 0, 0, 0)
#ScriptControllerConfig( "PORT_NAME", num_axes, "lua_script", "PARAMS=")
##ScriptControllerConfig("AMC-1", 3, "Attocube_AMC.lua", "PORT=AMC")
ScriptControllerConfig("AMC-1", 1, "AMC100.lua", "PORT=AMC")
ScriptAxisConfig("AMC-1", 0, "OPEN_LOOP='NO'")
##ScriptAxisConfig("AMC-1", 1, "OPEN_LOOP='NO'")
##ScriptAxisConfig("AMC-1", 2, "OPEN_LOOP='NO'")
#ScriptAxisConfig("AMC-1", 0, "OPEN_LOOP='YES'")
dbLoadTemplate("motor.substitutions.Attocube_AMC")
dbLoadRecords("/epics/devel/support/asyn/db/asynRecord.db", "P=XF:18IDB-ES{MCS:14}, R=Asyn, PORT=AMC, ADDR=0, OMAX=256, IMAX=256")
#asynSetTraceMask("MCS2", 0, 255)
asynSetTraceIOMask("MCS2", -1, 0x8)
asynManager:connectDevice port MCS2 not found
iocInit
Starting iocInit
## EPICS R7.0.5
## Rev. R7.0.5
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 40293,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
epics>
Sent: Wednesday, October 12, 2022 5:46 PM
To: Tech-talk <tech-talk at aps.anl.gov>; Ivashkevych, Oksana <oksana at bnl.gov>
This is a known issue with the current master branch of lua
Hello, When I run IOC of AMC100, I found this issue. Connect to virtual motor controller server drvAsynIPPortConfigure(&quot;AMC-1_IP&quot;,&quot;192.168.0.110:9090&quot;, 0, 0, 0) #ScriptControlle...
github.com
You can either use the latest tagged version instead, or define CXX11_SUPPORT=NO in CONFIG_SITE.local.Linux
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ivashkevych, Oksana via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, October 12, 2022 4:14 PM
Subject: Attocube AMC100
Hello,
We have a new Attocube AMC 100 unit.
I found the following communication about support of the new AMC controllers
https://epics.anl.gov/tech-talk/2021/msg01321.php
I built lua, motorScriptMotor within motor, and found st.cmd.Attocube_AMC startup script.
I am getting nullptr error and the core dump.
I have tried using AMC100.lua script (as was suggested in the link above) instead of Attocube_AMC.lua; renamed the port, thinking that some characters could be the culprit, yet I have same error and the core dump.
When I use vmc.lua I do not have the core dump. Just errors.
Thanks
iocScriptMotor]$ ../../bin/linux-x86_64/scriptMotor st.cmd.Attocube_AMC
< envPaths
epicsEnvSet("IP_ADDRESS", "10.66.138.144")
drvAsynIPPortConfigure("AMC","10.66.138.144:9090", 0, 0, 0)
ScriptControllerConfig("AMC-1", 2, "Attocube_AMC.lua", "PORT=AMC")
scriptMotor: ../../../luaApp/src/luaaa/luaaa.hpp:979: luaaa::LuaClass< <template-parameter-1-1> >::LuaClass(lua_State*, const char*, const luaL_Reg*) [with TCLASS = _apdWrapper; lua_State = lua_State; luaL_Reg = luaL_Reg]: Assertion `klassName == nullptr' failed.
Aborted (core dumped)
Re: Attocube AMC100 Kevin Peterson via Tech-talk
Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Re: Attocube AMC100 Lang, Keenan C. via Tech-talk
RE: Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Prev: Re: add motor module in synapps Kevin Peterson via Tech-talk
Next: PVAccess via TCP search Hill, Bruce via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Attocube AMC100 Lang, Keenan C. via Tech-talk
Next: Re: Attocube AMC100 Kevin Peterson via Tech-talk
ANJ, 19 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
