1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Attocube AMC300 driver?
From: "Lang, Keenan C. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Leicester, Pete (DLSLtd, RAL, LSCI)" <[email protected]>
Date: Fri, 16 Jul 2021 23:00:38 +0000
Pete,
I did just a quick set up of a scientist's AMC100, which should use the same json REST api.
However, it's using the scriptable motor driver (https://github.com/epics-motor/motorScriptMotor) due to me not wanting to deal with parsing a bunch of JSON in c/c++. So you'll need the master branch of that motor module and to build motor against the lua epics module (https://github.com/epics-modules/lua).
If you still would want to use it, I have the script here: https://github.com/keenanlang/Lua-Scripts/blob/master/motors/AMC100.lua
You'll also need to grab json.lua from here: https://github.com/rxi/json.lua (put it in your working directory or edit line 3 of AMC100.lua to add the path to the package search path)
Then the startup command calls are:
     drvAsynIPPortConfigure("AMC100-1_IP", "<INSERT IP HERE>:9090", 0,0,0)
     ScriptControllerConfig("AMC100-1", 2, "scripts/AMC100.lua", "PORT=AMC100-1_IP")
The support assumes a motor that has an encoder. If you're dealing with open loop steppers, it should just be a matter of switching the api method names in the move and poll functions (lines 46 and 79).
Or, at the very least, since the scriptable motor is pretty much 1-to-1 compared to a standard model 3 driver, it shouldn't be too bad to convert the logic to a c++ driver using https://github.com/nlohmann/json .
Keenan Lang
From: Tech-talk <[email protected]> on behalf of Leicester, Pete (DLSLtd, RAL, LSCI) via Tech-talk <[email protected]>
Sent: Friday, July 16, 2021 9:47 AM
To: [email protected] <[email protected]>
Subject: Attocube AMC300 driver?
Just wondering has anyone already written an EPICS driver for an Attocube AMC300?
AMC300 piezo motion controller (attocube.com)
Pete
Pete Leicester
Senior Software Systems Engineer
Diamond Light Source Ltd
Re: Attocube AMC300 driver? Kevin Peterson via Tech-talk
Attocube AMC300 driver? Leicester, Pete (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Next: Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Attocube AMC300 driver? Leicester, Pete (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Attocube AMC300 driver? Kevin Peterson via Tech-talk
