Subject: Re: linking in IOC makefile for RTEMS
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Siddons, David" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sat, 17 Jul 2021 11:44:27 -0700
On 7/16/21 12:47 PM, Siddons, David via Tech-talk wrote:
> Hi Andrew,
>   It doesn't seem to. The file is clearly compiled and included in the support library:
> /home/peter/quick-start/rtems/5/bin/arm-rtems5-ar rc   libmyexampleSupport.a    xxxRecord.o devXxxSoft.o dbSubExample.o devmyexampleVersion.o myexampleHello.o initTrace.o tarball.o
I'm not sure my 'epicsRtemsFSImage' trick will work from a library.
Try moving tarball.c to myexample_SRCS.
> myexample_SRCS += tarball.c
And I think you can just remove '..._SRCS += tarball.h'.
It's probably not doing anything helpful.
> arm-rtems5-nm libmyexampleSupport.a |grep epicsRtems
> 00000000 R epicsRtemsFSImage
> 00000000 R epicsRtemsFSImage_size
> but not in the myexample executable:
> peter@peter-OptiPlex-7070:~/test_ioc/bin/RTEMS-beagleboneblack$ arm-rtems5-nm myexample |grep epicsRtems
> 8060306c V epicsRtemsFSImage
> which is the weak symbol.
> Pete.
> *From:* Johnson, Andrew N. <[email protected]>
> *Sent:* Friday, July 16, 2021 3:21 PM
> *To:* Siddons, David <[email protected]>
> *Cc:* EPICS tech-talk <[email protected]>
> *Subject:* Re: linking in IOC makefile for RTEMS
> Hi Pete,
> Just an idea, does it make any difference if you remove the tarball.h file from your _SRCS variable (you shouldn’t include .h files in _SRCS anyway, if you want to install them they go into INC instead)?
> - Andrew
>> On Jul 16, 2021, at 2:08 PM, Siddons, David via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>> I have an RTEMS test IOC (generated using makeBaseApp) to which I've added a source file which declares a large array (actually, a compiled-in file system). The Makefile has:
>> # rather than directly into the IOC application, that
>> # causes problems on Windows DLL builds
>> myexampleSupport_SRCS += dbSubExample.c
>> myexampleSupport_SRCS += devmyexampleVersion.c
>> myexampleSupport_SRCS += myexampleHello.c
>> myexampleSupport_SRCS += initTrace.c
>> myexampleSupport_SRCS += tarball.h
>> myexampleSupport_SRCS += tarball.c
>> where the tarball files are my additions. The C file contains:
>>  *  Declarations for C structure representing binary file epicsRtemsFSImage
>>  *  WARNING: Automatically generated -- do not edit!
>> #include <sys/types.h>
>> const unsigned char epicsRtemsFSImage[] = {
>>   0x74, 0x61, 0x72, 0x62, 0x61, 0x6c, 0x6c, 0x2f, 0x00, 0x00, 0x00, 0x00,
>>   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
>>   .....etc, then:
>> const size_t epicsRtemsFSImage_size = sizeof(epicsRtemsFSImage);
>> The EPICS base libraries contain a weak reference to this same symbol (from libcom/RTEMS/init.c) , and I expected this definition to overwrite the weak one, but inspection of the executable only shows the weak one, and the size variable is not referenced at all. What am I missing? It seems that the tarball file is compiled, but not linked.
>> Pete.
> Complexity comes for free, simplicity you have to work for.
Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Re: linking in IOC makefile for RTEMS Johnson, Andrew N. via Tech-talk
Prev: Re: Attocube AMC300 driver? Lang, Keenan C. via Tech-talk
Next: Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Prev: Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
