Subject: Re: linking in IOC makefile for RTEMS
From: "Siddons, David via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 18 Jul 2021 18:41:35 +0000
Hi Michael,
   OK, you are right. That fixed the symbol problem and it now tries to mount the filesystem. Booting the resultant image I get:
***** Setting up file system *****
----- try to mount local filesystem ------
***** Using compiled in file data *****
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
R0   = 0x62726174 R8  = 0x00000000
R1   = 0x00000000 R9  = 0x00000000
R2   = 0x80812ce8 R10 = 0x00000000
R3   = 0x80856040 R11 = 0x00000000
R4   = 0x80456f50 R12 = 0x00000000
R5   = 0x80869198 SP  = 0x808690f0
R6   = 0x00000000 LR  = 0x801a997c
R7   = 0x00000000 PC  = 0x801aa73c
CPSR = 0x40000113 VEC = 0x00000004
RTEMS version: 5.0.0.1b3f09251ae53a93ea647e4d8ebeffeead91a880
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (1b3f09251ae5), Newlib 7947581)
executing thread ID: 0x08b010001
executing thread name:
The image was generated using the attached script, make-tarball.sh, and the current Makefile is also attached.
Pete.
Sent: Saturday, July 17, 2021 2:44 PM
To: Siddons, David <[email protected]>
Cc: EPICS tech-talk <[email protected]>; Johnson, Andrew N. <[email protected]>
On 7/16/21 12:47 PM, Siddons, David via Tech-talk wrote:
> Hi Andrew,
>   It doesn't seem to. The file is clearly compiled and included in the support library:
> /home/peter/quick-start/rtems/5/bin/arm-rtems5-ar rc   libmyexampleSupport.a    xxxRecord.o devXxxSoft.o dbSubExample.o devmyexampleVersion.o myexampleHello.o initTrace.o tarball.o
I'm not sure my 'epicsRtemsFSImage' trick will work from a library.
Try moving tarball.c to myexample_SRCS.
> myexample_SRCS += tarball.c
And I think you can just remove '..._SRCS += tarball.h'.
It's probably not doing anything helpful.
> arm-rtems5-nm libmyexampleSupport.a |grep epicsRtems
> 00000000 R epicsRtemsFSImage
> 00000000 R epicsRtemsFSImage_size
> but not in the myexample executable:
> peter@peter-OptiPlex-7070:~/test_ioc/bin/RTEMS-beagleboneblack$ arm-rtems5-nm myexample |grep epicsRtems
> 8060306c V epicsRtemsFSImage
> which is the weak symbol.
> Pete.
> *From:* Johnson, Andrew N. <[email protected]>
> *Sent:* Friday, July 16, 2021 3:21 PM
> *To:* Siddons, David <[email protected]>
> *Cc:* EPICS tech-talk <[email protected]>
> *Subject:* Re: linking in IOC makefile for RTEMS
> Hi Pete,
> Just an idea, does it make any difference if you remove the tarball.h file from your _SRCS variable (you shouldn’t include .h files in _SRCS anyway, if you want to install them they go into INC instead)?
> - Andrew
>> On Jul 16, 2021, at 2:08 PM, Siddons, David via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>> I have an RTEMS test IOC (generated using makeBaseApp) to which I've added a source file which declares a large array (actually, a compiled-in file system). The Makefile has:
>> # rather than directly into the IOC application, that
>> # causes problems on Windows DLL builds
>> myexampleSupport_SRCS += dbSubExample.c
>> myexampleSupport_SRCS += devmyexampleVersion.c
>> myexampleSupport_SRCS += myexampleHello.c
>> myexampleSupport_SRCS += initTrace.c
>> myexampleSupport_SRCS += tarball.h
>> myexampleSupport_SRCS += tarball.c
>> where the tarball files are my additions. The C file contains:
>>  *  Declarations for C structure representing binary file epicsRtemsFSImage
>>  *  WARNING: Automatically generated -- do not edit!
>> #include <sys/types.h>
>> const unsigned char epicsRtemsFSImage[] = {
>>   0x74, 0x61, 0x72, 0x62, 0x61, 0x6c, 0x6c, 0x2f, 0x00, 0x00, 0x00, 0x00,
>>   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
>>   .....etc, then:
>> const size_t epicsRtemsFSImage_size = sizeof(epicsRtemsFSImage);
>> The EPICS base libraries contain a weak reference to this same symbol (from libcom/RTEMS/init.c) , and I expected this definition to overwrite the weak one, but inspection of the executable only shows the weak one, and the size variable is not referenced at all. What am I missing? It seems that the tarball file is compiled, but not linked.
>> Pete.
> Complexity comes for free, simplicity you have to work for.
Attachment: make-tarball.sh
Description: make-tarball.sh
Attachment: Makefile
Description: Makefile
Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Re: linking in IOC makefile for RTEMS Johnson, Andrew N. via Tech-talk
Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Prev: Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
Next: Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
