1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Attocube AMC300 driver?
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Lang, Keenan C." <[email protected]>, "[email protected]" <[email protected]>, "Leicester, Pete (DLSLtd, RAL, LSCI)" <[email protected]>
Date: Tue, 20 Jul 2021 09:17:22 -0500
Keenan,
Are the lua scripts that have been written available on github? If not I propose adding them to the Lua ScriptMotor repo:
  https://github.com/epics-motor/motorScriptMotor
Kevin
P.S. The link is for everyone else; I know you know where the script motor support lives.
On 7/16/21 6:00 PM, Lang, Keenan C. via Tech-talk wrote:
Pete,
I did just a quick set up of a scientist's AMC100, which should use the same json REST api.
However, it's using the scriptable motor driver (https://github.com/epics-motor/motorScriptMotor <https://github.com/epics-motor/motorScriptMotor>) due to me not wanting to deal with parsing a bunch of JSON in c/c++. So you'll need the master branch of that motor module and to build motor against the lua epics module (https://github.com/epics-modules/lua <https://github.com/epics-modules/lua>).
If you still would want to use it, I have the script here: https://github.com/keenanlang/Lua-Scripts/blob/master/motors/AMC100.lua <https://github.com/keenanlang/Lua-Scripts/blob/master/motors/AMC100.lua>
You'll also need to grab json.lua from here: https://github.com/rxi/json.lua <https://github.com/rxi/json.lua> (put it in your working directory or edit line 3 of AMC100.lua to add the path to the package search path)
Then the startup command calls are:
      drvAsynIPPortConfigure("AMC100-1_IP", "<INSERT IP HERE>:9090", 0,0,0)
     ScriptControllerConfig("AMC100-1", 2, "scripts/AMC100.lua", "PORT=AMC100-1_IP")
The support assumes a motor that has an encoder. If you're dealing with open loop steppers, it should just be a matter of switching the api method names in the move and poll functions (lines 46 and 79).
Or, at the very least, since the scriptable motor is pretty much 1-to-1 compared to a standard model 3 driver, it shouldn't be too bad to convert the logic to a c++ driver using https://github.com/nlohmann/json <https://github.com/nlohmann/json> .
Keenan Lang
Attocube AMC300 driver? Leicester, Pete (DLSLtd, RAL, LSCI) via Tech-talk
Re: Attocube AMC300 driver? Lang, Keenan C. via Tech-talk
Prev: Re: CAEN VME crate with controller card plus digitizers Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Software Architecture training Rees, Nick via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Attocube AMC300 driver? Lang, Keenan C. via Tech-talk
Next: Syncronising triggred data acquisition for Modbus "I/O Intr" records and sscan records Kuldeep Joshi via Tech-talk
