1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Attocube AMC100
From: "Ivashkevych, Oksana via Tech-talk" <tech-talk at aps.anl.gov>
To: "Cyl, David C." <davecyl at anl.gov>, "Peterson, Kevin M." <kmpeters at anl.gov>, "Lang, Keenan C." <klang at anl.gov>, Tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 20 Oct 2022 21:46:38 +0000
Hi Dave,
Thank you and APS team for sharing your code and findings.
The changes you suggested in the Stop() function work much better!!
Before the motor actually stopped, after ~30 seconds.  One needed to be patient and not panic. I made this discovery accidently.
I have done ~ 50 tests. When one makes a long move and presses stop, it does stop after a few (up to 10 sec ) delay. In most cases the target position is updated to the current position and the motor stays at rest. In a few cases, however,  the target position is not updated, and the motor moves again after checking on other motors, ( a while). It seems after the second stop it is updated.
Also, I added a the stop command after limits detection in the poll().  And this actually works quite well. The motor power output stops almost immediately after reporting a limit,  and when the targeted position is not updated, and the move command comes again, it gets updated the second time.
This code also address the situation when motor is on the pos limit for example and  is commanded to go positive. It did output power before, now it doesn't
Poll()
if (status == "backward limit reached") then
                low_lim = 1
                local request = {
                        jsonrpc = "2.0",
                        method = "com.attocube.amc.control.setControlMove",
                        params = { AXIS, false},
                        id = AXIS,
                        api = 2 }
                send(request)
        end
        if (status == "forward limit reached") then
                high_lim = 1
                local request = {
                        jsonrpc = "2.0",
                        id = AXIS,
                        api = 2 }
                send(request)
        end
It would be nice to push all these updates to the github.
For the enabling output, I enabled the motors via vendor app, and yes, it gets disabled after the power cycle.
With best regards,
Oksana
-----Original Message-----
Sent: Wednesday, October 19, 2022 4:28 PM
To: Peterson, Kevin M. <kmpeters at anl.gov>; Ivashkevych, Oksana <oksana at bnl.gov>; Lang, Keenan C. <klang at anl.gov>; Tech-talk <tech-talk at aps.anl.gov>
Subject: Re: Attocube AMC100
Another issue I ran into was with the stage enable, on the web view you can enable or disable a stage. I tried to do this via the setControlOutput command using the torque enable/disable button  and it did toggle the enable state but when I then read back this state via the getControlOutput it was flipping from true/false and I still have no idea why. I did open a case with attocube and if I get an answer I will post here.
Here is a snippet of the code that gets executed upon a closedLoop state change.
        if(closedLoop) then
                local request = {
                        jsonrpc = "2.0",
                        method =
"com.attocube.amc.control.setControlOutput",
                        params = { AXIS, 1 },
                        id = AXIS,
                        api = 2 }
                send(request)
        else
                local request = {
                        jsonrpc = "2.0",
                        method =
                        params = { AXIS, 0 },
                        id = AXIS,
                        api = 2 }
                send(request)
Re: Attocube AMC100 Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Re: Attocube AMC100 Lang, Keenan C. via Tech-talk
RE: Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Re: Attocube AMC100 Kevin Peterson via Tech-talk
Re: Attocube AMC100 Cyl, David C. via Tech-talk
Prev: Re: starting ImageJ/EPICS_AD_Viewer with specified PVPrefix John Dobbins via Tech-talk
Next: Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Attocube AMC100 Cyl, David C. via Tech-talk
Next: Re: Attocube AMC100 Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
ANJ, 28 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
