1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Attocube AMC100
From: "Perez Juarez, Emilio \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "Cyl, David C." <[email protected]>, "Peterson, Kevin M." <[email protected]>, "Lang, Keenan C." <[email protected]>, Tech-talk <[email protected]>, "Ivashkevych, Oksana" <[email protected]>
Date: Fri, 28 Oct 2022 10:54:29 +0000
Hi all,
In case it's useful, I'd like to point to the relevant support module we are using at DLS, it's in https://github.com/dls-controls/amc100
Kind Regards,
Emilio
From: Tech-talk <[email protected]> on behalf of Ivashkevych, Oksana via Tech-talk <[email protected]>
Sent: 20 October 2022 22:46
To: Cyl, David C. <[email protected]>; Peterson, Kevin M. <[email protected]>; Lang, Keenan C. <[email protected]>; Tech-talk <[email protected]>
Subject: RE: Attocube AMC100
Hi Dave,
Thank you and APS team for sharing your code and findings.
The changes you suggested in the Stop() function work much better!!
Before the motor actually stopped, after ~30 seconds.  One needed to be patient and not panic. I made this discovery accidently.
I have done ~ 50 tests. When one makes a long move and presses stop, it does stop after a few (up to 10 sec ) delay. In most cases the target position is updated to the current position and the motor stays at rest. In a few cases, however,  the target position is not updated, and the motor moves again after checking on other motors, ( a while). It seems after the second stop it is updated.
Also, I added a the stop command after limits detection in the poll().  And this actually works quite well. The motor power output stops almost immediately after reporting a limit,  and when the targeted position is not updated, and the move command comes again, it gets updated the second time.
This code also address the situation when motor is on the pos limit for example and  is commanded to go positive. It did output power before, now it doesn't
Poll()
if (status == "backward limit reached") then
                low_lim = 1
                local request = {
                        jsonrpc = "2.0",
                        method = "com.attocube.amc.control.setControlMove",
                        params = { AXIS, false},
                        id = AXIS,
                        api = 2 }
                send(request)
        end
        if (status == "forward limit reached") then
                high_lim = 1
                local request = {
                        jsonrpc = "2.0",
                        id = AXIS,
                        api = 2 }
                send(request)
        end
It would be nice to push all these updates to the github.
For the enabling output, I enabled the motors via vendor app, and yes, it gets disabled after the power cycle.
With best regards,
Oksana
-----Original Message-----
Sent: Wednesday, October 19, 2022 4:28 PM
To: Peterson, Kevin M. <[email protected]>; Ivashkevych, Oksana <[email protected]>; Lang, Keenan C. <[email protected]>; Tech-talk <[email protected]>
Another issue I ran into was with the stage enable, on the web view you can enable or disable a stage. I tried to do this via the setControlOutput command using the torque enable/disable button  and it did toggle the enable state but when I then read back this state via the getControlOutput it was flipping from true/false and I still have no idea why. I did open a case with attocube and if I get an answer I will post here.
Here is a snippet of the code that gets executed upon a closedLoop state change.
        if(closedLoop) then
                local request = {
                        jsonrpc = "2.0",
                        method =
"com.attocube.amc.control.setControlOutput",
                        params = { AXIS, 1 },
                        id = AXIS,
                        api = 2 }
                send(request)
        else
                local request = {
                        jsonrpc = "2.0",
                        method =
                        params = { AXIS, 0 },
                        id = AXIS,
                        api = 2 }
                send(request)
Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Re: Attocube AMC100 Lang, Keenan C. via Tech-talk
RE: Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Re: Attocube AMC100 Kevin Peterson via Tech-talk
Re: Attocube AMC100 Cyl, David C. via Tech-talk
Prev: Missing DLL entry points in PV utils on windows-x64-mingw? Eloise de Castelnau via Tech-talk
Next: Grabbing data from REST API Sean Leavey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: Attocube AMC100 Ivashkevych, Oksana via Tech-talk
Next: Segmentation fault when using asyn Octect writeRead Abdalla Ahmad via Tech-talk
