Instead of using an Ellipse with a rule to update the color and another rule to update
the tooltip with the value text, just use an LED or Multi-state LED where all you need to enter is the PV name
... plus that will then also work in the web runtime
From: Tech-talk on behalf of Carsten Winkler via Tech-talk
Sent: Thursday, December 8, 2022 6:20 AM
To: tech-talk at aps.anl.gov
Subject: [EXTERNAL] Phoebus Rules for Tooltips
Hello, does anyone have any idea why the rule for the tooltip is not
outputting the variable value? Any help is appreciated. Many greetings,
Carsten
<?xml version="1.0" encoding="UTF-8"?>
<display version="2.0.0">
<widget type="ellipse" version="2.0.0">
<name>Release LED</name>
<x>27</x>
<y>49</y>
<width>20</width>
<height>20</height>
<line_width>2</line_width>
<line_color>
<color red="0" green="0" blue="0">
</color>
</line_color>
<background_color>
<color red="204" green="204" blue="204">
</color>
</background_color>
<rules>
<rule name="color" prop_id="background_color" out_exp="false">
<exp bool_exp="pvSev0 == -1">
<value>
</color>
</value>
</exp>
<exp bool_exp="pvSev0 == 0">
<value>
<color red="30" green="187" blue="0">
</color>
</value>
</exp>
<exp bool_exp="pvSev0 == 1">
<value>
<color red="249" green="218" blue="60">
</color>
</value>
</exp>
<exp bool_exp="pvSev0 == 2">
<value>
<color red="255" green="0" blue="0">
</color>
</value>
</exp>
<pv_name>V08V01U315L:Lock</pv_name>
</rule>
<rule name="tooltip" prop_id="tooltip" out_exp="false">
<exp bool_exp="true">
<value>pvStr0</value>
</exp>
</rule>
</rules>
<tooltip>???</tooltip>
</widget>
</display>
Carsten Winkler
Software Developer
BE-IA-AOT / AG ELIS
________________________________________________________________________________________________
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten. Wenn Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den*die Absender*in und vernichten Sie diese Mail. Das unerlaubte Kopieren, die Veröffentlichung
sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This email may contain confidential and/or proprietary information. If you have received this e-mail in error, please inform the sender immediately and destroy this e-mail. Unauthorized copying, publishing or distribution of this e-mail is not permitted.
Phoebus Rules for Tooltips Carsten Winkler via Tech-talk
Re: A simple EPICS driver example for PCI devices using asynPortDriver on Linux Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
<2022>
2025
Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection Wang, Andrew via Tech-talk
<2022>
2025
ANJ, 08 Dec 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
